Local Time 13:45 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Strange Case: WakeUp on MX470.64pin
sagt3k
Posted: 09:48am 26 Mar 2017
Hi to everybody
I am using PIC32MX.64pin with firmware 05.03.02. I use pin(51) to simulate wakeup action etc.
If the micro is NOT connected to USB and I do "cpu sleep" after I can use Pin(51), the micro answer correctly and continues to run.
While if I connect micro with USB makes some strange behavior. Sometimes "cpu sleep" It has no effect does not go into sleep. Some time after giving the command "cpu sleep" even if I use the pin (51) does not wake up again and I have to do a reset.
what's the problem ? where am wrong
sagt3kEdited by sagt3k 2017-03-27
Posted: 03:20pm 26 Mar 2017
You will have trouble if you have an active USB connection and use sleep. This is something I should have mentioned in the documentation.
Sleep is all about saving power in a battery powered application so in a practical situation it should not matter because there is little reason to send the Micromite to sleep if you have an active USB connection.
sagt3k
Posted: 08:51am 27 Mar 2017
Hi Geoff
OK Clear, but is it possible to have a variable MM.USB=1 that indicates a USB console connection? Or is it possibile to have no action with "cpu sleep" when is actvie USB connection?
sagt3k
CircuitGizmos
Posted: 10:41am 27 Mar 2017
  sagt3k said  is it possible to have a variable MM.USB=1 that indicates a USB console connection?
I like that. Seconded.
Posted: 11:49am 27 Mar 2017
  Quote  is it possible to have a variable MM.USB=1 that indicates a USB console connection?
? peek(word &HBF885060) and 1
will tell you if the USB is plugged in
1=yes
0=no
sagt3k
Posted: 06:55am 28 Mar 2017
Hi matherp
I tried with USB console and give me 1 and later with UART on TX/RX as console ... same result=1.
Where is the error?
I'm trying on PIC32MX470H.64pin with MMbasic "5.0302".
sagt3k
Posted: 08:19am 28 Mar 2017
This is showing power to the VBUS pin-34 (on 64-pin). If you have power on that pin USB is enabled whether you want it or not
sagt3k
Posted: 08:58am 28 Mar 2017
Hi matherp
Thanks solved.
But I don't know very well PIC32MX/MZ with various pin. But this address(&HBF885060) is equal on all PIC32xx ?
Or Can you think to implement MM.USB ?
sagt3k
sagt3k
Posted: 11:10am 18 Sep 2017
Hi matherp
Concerning PIC32MZ2048EFH 64pin, What is the address to read if connected with USB or no?
sagt3k
