Local Time 23:20 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Syntax DATE$ vs. manual.
Paul_L
Posted: 12:49am 24 Mar 2017
The 5.2 manual says:
DATE$ = "DD-MM-YY"
or
DATE$ = "DD/MM/YY"
Set the date of the internal clock/calendar.
DD, MM and YY are numbers, for example: DATE$ = "28-7-2014"
The date is set to "1-1-2000" on power up.
Shouldn't it read:
DD, MM and YY are numbers, for example: DATE$ = "28-07-2014"
The date is set to "01-01-2000" on power up.
Paul in NY
Posted: 07:59am 24 Mar 2017
OK, good point.
