Local Time 22:21 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - Earth satellite rise and set
cdeagle
Posted: 06:20am 23 Mar 2017
This post describes a MMBASIC program for the MicroMite eXtreme that can be used to calculate visibility conditions of Earth satellites. The software uses Two-Line Element (TLE) information to calculate visibility. The sat_riseset.bas computer code allows the user to specify a minimum elevation angle during the analysis. Shadow conditions at rise, maximum elevation and set are also displayed if valid.
TLE data for a variety of space objects can be downloaded from Dr. Kelso's CeleTrak website located at
https://celestrak.com/NORAD/elements/
The data for the object of interest must be extracted from the TLE file and added to the sat_riseset.bas source code via three lines of strings as follows;
' TLE data
cline1 = "ISS (ZARYA)"
cline2 = "1 25544U 98067A 17077.64837083 .00001665 00000-0 32320-4 0 9993"
cline3 = "2 25544 51.6420 129.6155 0006880 308.3866 194.6632 15.54222906 47676"
Always use the TLE data with a calendar date closest to your calendar date of interest.
Here's a typical user interaction with this computer program. It first displays the TLE epoch along with the data used by the software. This example displays conditions of the International Space Station (ISS) relative to Cape Canaveral, Florida.
rise and set of Earth satellites
TLE epoch
calendar date March 18 2017
UTC 15 hours 33 minutes 39.07 seconds
ISS (ZARYA)
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 3,23,2017
please input the UTC time
(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])
? 4,0,0
please input the geographic latitude of the observer
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? 28,23,45
please input the geographic longitude of the observer
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
? -80,35,55
please input the altitude of the observer (meters)
(positive above sea level, negative below sea level)
? 0
please input the number of days to simulate
? 1
please input the minimum elevation angle (degrees)
? 10
Here is the program output for this example.
rise conditions
calendar date March 23 2017
UTC 9 hours 40 minutes 20.33 seconds
UTC julian day 2457835.90301302
topocentric coordinates
azimuth angle 352 deg 24 min 21.35 sec
elevation angle 10 deg 0 min 0.00 sec
slant range 1470.7678 kilometers
azimuth rate 0.2029 degrees/second
elevation rate 0.0445 degrees/second
range rate -4.8883 kilometers/second
umbra shadow
maximum elevation conditions
UTC 9 hours 42 minutes 45.25 seconds
UTC julian day 2457835.90469039
azimuth angle 39 deg 36 min 24.61 sec
elevation angle 18 deg 34 min 55.55 sec
slant range 1056.9589 kilometers
azimuth rate 0.4212 degrees/second
elevation rate -0.0002 degrees/second
range rate -0.0097 kilometers/second
set conditions
UTC 9 hours 45 minutes 9.77 seconds
UTC julian day 2457835.90636313
azimuth angle 86 deg 47 min 11.40 sec
elevation angle 10 deg 0 min 0.06 sec
slant range 1467.3834 kilometers
azimuth rate 0.2036 degrees/second
elevation rate -0.0448 degrees/second
range rate 4.8844 kilometers/second
event duration 0 hours 4 minutes 49.45 seconds
rise conditions
UTC 11 hours 16 minutes 23.56 seconds
UTC julian day 2457835.96971717
azimuth angle 290 deg 35 min 37.76 sec
slant range 1468.6603 kilometers
azimuth rate -0.1526 degrees/second
elevation rate 0.0527 degrees/second
range rate -5.8094 kilometers/second
UTC 11 hours 19 minutes 11.51 seconds
UTC julian day 2457835.97166102
azimuth angle 232 deg 18 min 58.05 sec
elevation angle 25 deg 37 min 46.68 sec
slant range 847.4275 kilometers
azimuth rate -0.5524 degrees/second
elevation rate -0.0005 degrees/second
range rate -0.0152 kilometers/second
set conditions
UTC 11 hours 21 minutes 58.84 seconds
UTC julian day 2457835.97359774
azimuth angle 173 deg 55 min 59.61 sec
slant range 1461.7028 kilometers
azimuth rate -0.1546 degrees/second
elevation rate -0.0532 degrees/second
range rate 5.7904 kilometers/second
event duration 0 hours 5 minutes 35.28 seconds
rise conditions
calendar date March 24 2017
UTC 0 hours 40 minutes 8.03 seconds
UTC julian day 2457836.52787070
azimuth angle 150 deg 46 min 45.39 sec
slant range 1443.1546 kilometers
azimuth rate -0.2686 degrees/second
elevation rate 0.0272 degrees/second
range rate -2.9261 kilometers/second
umbra shadow
UTC 0 hours 41 minutes 32.30 seconds
UTC julian day 2457836.52884611
azimuth angle 124 deg 53 min 8.58 sec
elevation angle 12 deg 15 min 48.49 sec
slant range 1315.3239 kilometers
azimuth rate -0.3288 degrees/second
elevation rate 0.0003 degrees/second
range rate 0.0324 kilometers/second
umbra shadow
set conditions
UTC 0 hours 42 minutes 56.79 seconds
UTC julian day 2457836.52982397
azimuth angle 99 deg 1 min 56.17 sec
elevation angle 10 deg 0 min 0.01 sec
slant range 1448.8546 kilometers
azimuth rate -0.2664 degrees/second
elevation rate -0.0267 degrees/second
range rate 2.9844 kilometers/second
umbra shadow
event duration 0 hours 2 minutes 48.76 seconds
rise conditions
UTC 2 hours 14 minutes 43.26 seconds
UTC julian day 2457836.59355621
azimuth angle 249 deg 9 min 33.01 sec
slant range 1447.2065 kilometers
azimuth rate 0.1196 degrees/second
elevation rate 0.0575 degrees/second
range rate -6.2459 kilometers/second
umbra shadow
UTC 2 hours 17 minutes 42.99 seconds
UTC julian day 2457836.59563647
azimuth angle 316 deg 38 min 23.21 sec
elevation angle 33 deg 51 min 59.64 sec
slant range 683.7368 kilometers
azimuth rate 0.7440 degrees/second
elevation rate 0.0010 degrees/second
range rate 0.0180 kilometers/second
umbra shadow
set conditions
UTC 2 hours 20 minutes 44.11 seconds
UTC julian day 2457836.59773279
azimuth angle 24 deg 8 min 14.14 sec
slant range 1457.9380 kilometers
azimuth rate 0.1185 degrees/second
elevation rate -0.0565 degrees/second
range rate 6.2475 kilometers/second
umbra shadow
event duration 0 hours 6 minutes 0.86 seconds
Here's a zip archive that contains the MMBASIC source code and two PDF documents that may be helpful. In the riseset.pdf document, the MATLAB riseset2.m program corresponds to this MMBASIC implementation.
2017-03-23_153747_sat_riseset.zip
