Local Time 23:16 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SC DDS signal generator,
palcal
Posted: 11:30am 22 Mar 2017
This months SC has a signal generator based on the Micromite Backpack. I went straight to the ali express web site nominated in the srticle to buy one (about US$11) but they were sold out. However SC are selling them for $25 plus about $10 postage. I must say the rest of the mag was a bit of a bore as usual, bring on the new mag DIYODE it can't be any worse.
I will search the web for the module and see what I can find.
Paul.
Edit. I can't find any on the web maybe someone else may have some luck.Edited by palcal 2017-03-23
Bill7300
Posted: 01:05pm 22 Mar 2017
My Silicon Chip issue has yet to arrive but what exactly are you looking for on the web?
damos
Posted: 01:33pm 22 Mar 2017
I uploaded an article last year using this module, which is really cheap and easy to get:
AD9833 Module on eBay
There is discussion
here
The SC article uses a module that has a gain stage and a built in level control.
My design uses and incremental encoder for set the frequency and level, which I prefer by far. I put a lot of work into the code for the encoder so it behaves like a good analog instrument - no matter what frequency you are on, it adjusts the step to allow you to quickly sweep a band with a flick of the wrist. For example, at 1kHz going counter clockwise will subtract 100Hz for each step, while above a couple of kHz it will switch to a larger step.
Dan
Posted: 02:09pm 22 Mar 2017
I was caught out when I went looking for the module too.
But Geoff assured me they were still available.
I just had to set my EBay search to world-wide and there they were.
This is the one I ordered:
http://www.ebay.com.au/itm/331851695524?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Or search ebay for "AD9833 DDS Signal Generator Module 0-12.5MHz Square / Triangle / Sine Wave"
Having the gain available makes using it much easier.
palcal
Posted: 07:28pm 22 Mar 2017
Thanks Jim, I have ordered one.
Paul.
Posted: 01:12am 23 Mar 2017
For people who do not get Silicon Chip the Signal Generator is described on my website at http://geoffg.net/SignalGenerator.html
RonnS
Posted: 02:15am 23 Mar 2017
thank you Geoff,
that project looks very professional
regards Ron
jman
Posted: 06:28pm 24 Mar 2017
Hi
I have been playing with Geoff's software and found a small issue.
If you select sweep mode then tap the sweep time +- 5 times in row fairly quickly the following error occurs then the watchdog reboots and all is well again
Could somebody else confirm this is the case or is it just me.
Jman
Posted: 11:52pm 24 Mar 2017
That is an obscure bug. I'm tempted to say that the cure is "don't do it" but I will have a look when I get back.
