Local Time 23:19 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : output of MEMORY command into variable?
Posted: 08:15am 16 Mar 2017
Maybe it's obvious, but I searched and didn't see anything about getting the output of the MEMORY command into a variable so it could be parsed.
Is there a way to do this?
disco4now
Posted: 11:45am 16 Mar 2017
What about connecting Console TX pin to COM1 RX pin and then reading the input via COM1.
F4 H7FotSF4xGT
Zonker
Posted: 03:36pm 16 Mar 2017
Maybe there is a "Peek" address that holds this data in the firmware memory area...
I sure don't know, but maybe someone here does...
I wonder if there is a list of useful things to Peek at..?
Posted: 08:07pm 16 Mar 2017
No, at this time there is no method of discovering the amount of free memory from within the program.
This is my current list of peakable items:
Is AUTORUN on? Returns 1 if yes or 0 if no
peek(byte peek(word &H9D000090))
The current display type
peek(byte peek(word &H9D000090) + 20)
where:
No Display = 0
SSD1963_4 = 1
SSD1963_5 = 2
SSD1963_5A = 3
SSD1963_7 = 4
SSD1963_7A = 5
SSD1963_8 = 6
ILI9341 = 7
ILI9163 = 8
ST7735 = 9
The display orientation (1 = landscape, 2 = portrait, 3 = RevL, 4 = RevP)
peek(byte peek(word &H9D000090) + 21)
The I/O pin used for touch CS (zero means that touch is not configured)
peek(byte peek(word &H9D000090) + 22)
The I/O pin used for touch INT (handy if you want to set an interrupt on touch)
peek(byte peek(word &H9D000090) + 23)
Is the touch calibrated? Zero means no, non zero yes.
peek(word peek(word &H9D000090) + 28)
The I/O pin used for the LCD CS (zero means that the LCD is not configured)
peek(byte peek(word &H9D000090) + 45)
The I/O pin used for the LCD CD
peek(byte peek(word &H9D000090) + 44)
The I/O pin used for the LCD reset
peek(byte peek(word &H9D000090) + 46)
The I/O pin used for the SD card CS (zero means that the SD card is not configured)
peek(byte peek(word &H9D000090) + 48)
What MMBasic thinks is the width of the console in characters
peek(byte peek(word &H9D000090) + 5)
What MMBasic thinks is the height of the console in lines
peek(byte peek(word &H9D000090) + 4)
Posted: 02:58am 17 Mar 2017
Thanks for the responses.
disco4now--not practical in this circuit.
Posted: 06:04am 28 Mar 2017
Hi Geoff. Do you have a similar list (just the starting address?) for 5.03.15 - I haven't tested them all but the first two PEEKs give me an error on the MMX+ (144 pin jobby)
> print peek(byte peek(word &H9D000090) + 20)
Error: Invalid address
cheers
Posted: 08:11am 28 Mar 2017
  CaptainBoing said   Hi Geoff. Do you have a similar list (just the starting address?) for 5.03.15 - I haven't tested them all but the first two PEEKs give me an error on the MMX+ (144 pin jobby)
I think Peter will have to chime in here (rather than Geoff)
I agree, this list for MMX will be useful
Posted: 09:29am 28 Mar 2017
sorry - yes you are quite correct.
hi Geoff/Peter...
cheers
