Local Time 21:20 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - Hohmann transfer
cdeagle
Posted: 12:38am 16 Mar 2017
This post describes a MicroMite eXtreme computer program that solves one of the classic problems of orbit mechanics, the Hohmann Transfer. This orbital maneuver provides an estimate of the geometry and propulsion requirements for transferring a spacecraft between two circular orbits.
The following is a typical user interaction with the software. It is a typical LEO (low Earth orbit) to GEO (geosynchronous Earth orbit) transfer with a 28.5 degree plane change.
Hohmann Orbit Transfer Analysis
please input the initial altitude (kilometers)
? 300
please input the final altitude (kilometers)
? 35786.2
please input the initial orbital inclination (degrees)
(0 <= inclination <= 180))
? 28.5
please input the final orbital inclination (degrees)
? 0
Here's the program output for this example.
initial orbit altitude 300.0000 kilometers
initial orbit radius 6678.1363 kilometers
initial orbit inclination 28.5000 degrees
initial orbit velocity 7725.7606 meters/second
final orbit altitude 35786.2000 kilometers
final orbit radius 42164.3363 kilometers
final orbit inclination 0.0000 degrees
final orbit velocity 3074.6540 meters/second
first inclination change 2.2002 degrees
second inclination change 26.2998 degrees
total inclination change 28.5000 degrees
first delta-v 2449.4551 meters/second
second delta-v 1781.8532 meters/second
total delta-v 4231.3083 meters/second
transfer orbit semimajor axis 24421.2363 kilometers
transfer orbit eccentricity 0.72654389
transfer orbit inclination 26.2998 degrees
transfer orbit perigee velocity 10151.4962 meters/second
transfer orbit apogee velocity 1607.8298 meters/second
transfer orbit coast time 18990.3276 seconds
316.5055 minutes
5.2751 hours
For additional information about the Hohmann transfer, here is a link to the MATLAB version of the user's manual in PDF format.
2017-03-16_103118_hohmann.pdf
The following is the MMBASIC source code for this example. The program uses R. P. Brent's root-finding method to calculate the optimum partitioning of the plane change.
' hohmann.bas March 16, 2017
' Hohmann two impulse orbit transfer between
' planar and non-coplanar circular orbits
' Micromite eXtreme version
option default float
dim hn1, hn2, hn3, dinc, rtol, maxiter, niter
dim alt1, alt2, inc1, inc2, rmin, rmax
' astrodynamic and utility constants
const dtr = pi / 180.0
const rtd = 180.0 / pi
' earth gravitational constant (km^3/sec^2)
const mu = 398600.436233
' earth equatorial radius (kilometers)
const req = 6378.1363
' root-finding tolerance
rtol = 1.0e-8
' maximum number of root-finding iterations allowed
maxiter = 100
' request inputs
print " "
print "Hohmann Orbit Transfer Analysis"
print "==============================="
print " "
do
print " "
print "please input the initial altitude (kilometers)"
input alt1
if (alt1 > 0.0) then
exit do
end if
loop
do
print " "
print "please input the final altitude (kilometers)"
input alt2
if (alt2 > 0.0) then
exit do
end if
loop
do
print " "
print "please input the initial orbital inclination (degrees)"
print "(0 <= inclination <= 180))"
input inc1
if (inc1 >= 0.0 and inc1 <= 180.0) then
exit do
end if
loop
do
print " "
print "please input the final orbital inclination (degrees)"
print "(0 <= inclination <= 180)"
input inc2
if (inc2 >= 0.0 and inc2 <= 180.0) then
exit do
end if
loop
' convert orbit inclinations to radians
inc1 = inc1 * dtr
inc2 = inc2 * dtr
' solve the orbit transfer problem '
' calculate total inclination change (radians)
dinc = abs(inc2 - inc1)
' compute geocentric radii of initial and final orbits (kilometers)
r1 = req + alt1
r2 = req + alt2
' compute "normalized" radii
hn1 = sqr(2.0 * r2 / (r2 + r1))
hn2 = sqr(r1 / r2)
hn3 = sqr(2.0 * r1 / (r2 + r1))
' compute "local circular velocity" of initial and final orbits (km/sec)
v1 = sqr(mu / r1)
v2 = sqr(mu / r2)
' compute transfer orbit semimajor axis (kilometers)
smat = 0.5 * (r1 + r2)
' compute transfer orbit eccentricity (non-dimensional)
if (r1 > r2) then
rmax = r1
else
rmax = r2
end if
if (r1 < r2) then
rmin = r1
else
rmin = r2
end if
ecct = (rmax - rmin) / (r1 + r2)
' compute transfer orbit perigee and apogee radii and velocities
rp = smat * (1.0 - ecct)
ra = smat * (1.0 + ecct)
vt1 = sqr(2.0 * mu * ra / (rp * (rp + ra)))
vt2 = sqr(2.0 * mu * rp / (ra * (rp + ra)))
' compute transfer orbit period (seconds)
taut = 2.0 * pi * sqr(smat^3 / mu)
tof = 0.5 * taut
if (abs(dinc) = 0.0) then
' coplanar orbit transfer
if (r2 > r1) then
' higher-to-lower transfer
dv1 = vt1 - v1
dv2 = v2 - vt2
else
' lower-to-higher transfer
dv1 = v1 - vt2
dv2 = vt1 - v2
end if
dinc1 = 0.0
dinc2 = 0.0
inct = inc1
else
' non-coplanar orbit transfer
realroot(0, dinc, rtol, maxiter, niter, xroot, froot)
' calculate delta-v's
dinc1 = xroot
dinc2 = dinc - dinc1
dv1 = v1 * sqr(1.0 + hn1 * hn1 - 2.0 * hn1 * cos(dinc1))
dv2 = v1 * sqr(hn2 * hn2 * hn3 * hn3 + hn2 * hn2 - 2.0 * hn2 * hn2 * hn3 * cos(dinc2))
if (inc2 > inc1) then
inct = inc1 + dinc1
else
inct = inc1 - dinc1
end if
end if
' print results
print " "
print " "
print "initial orbit altitude ", str$(alt1, 0, 4), " kilometers"
print " "
print "initial orbit radius ", str$(alt1 + req, 0, 4), " kilometers"
print " "
print "initial orbit inclination ", str$(inc1 * rtd, 0, 4), " degrees"
print " "
print "initial orbit velocity ", str$(1000.0 * v1, 0, 4), " meters/second"
print " "
print " "
print "final orbit altitude ", str$(alt2, 0, 4), " kilometers"
print " "
print "final orbit radius ", str$(alt2 + req, 0, 4), " kilometers"
print " "
print "final orbit inclination ", str$(inc2 * rtd, 0, 4), " degrees"
print " "
print "final orbit velocity ", str$(1000.0 * v2, 0, 4), " meters/second"
print " "
print " "
print "first inclination change ", str$(dinc1 * rtd, 0, 4), " degrees"
print " "
print "second inclination change ", str$(dinc2 * rtd, 0, 4), " degrees"
print " "
print "total inclination change ", str$(rtd * (dinc1 + dinc2), 0, 4), " degrees"
print " "
print " "
print "first delta-v ", str$(1000.0 * dv1, 0, 4), " meters/second"
print " "
print "second delta-v ", str$(1000.0 * dv2, 0, 4), " meters/second"
print " "
print "total delta-v ", str$(1000.0 * (dv1 + dv2), 0, 4), " meters/second"
print " "
print " "
print "transfer orbit semimajor axis ", str$(smat, 0, 4), " kilometers"
print " "
print "transfer orbit eccentricity ", str$(ecct, 0, 8)
print " "
print "transfer orbit inclination ", str$(rtd * inct, 0, 4), " degrees"
print " "
print "transfer orbit perigee velocity ", str$(1000.0 * vt1, 0, 4), " meters/second"
print " "
print "transfer orbit apogee velocity ", str$(1000.0 * vt2, 0, 4), " meters/second"
print " "
print " "
print "transfer orbit coast time ", str$(tof, 0, 4), " seconds"
print " ", str$(tof / 60.0, 0, 4), " minutes"
print " ", str$(tof / 3600.0, 0, 4), " hours"
end
sub hohmfunc (x, fx)
' inclination objective function
' input
' x = function argument
' output
' fx = function value
local hn, a, b
dinc1 = x
hn = hn2 * hn2
a = hn1 * sin(dinc1) / sqr(1.0 + hn1 * hn1 - 2.0 * hn1 * cos(dinc1))
b = hn * hn3 * (sin(dinc) * cos(dinc1) - cos(dinc) * sin(dinc1))
' calculate objective function value
fx = a - b / sqr(hn * hn3 * hn3 + hn - 2.0 * hn * hn3 * cos(dinc - dinc1))
end sub
sub realroot(xl, xu, tol, maxiter, niter, xroot, froot)
' real root of a single non-linear function subroutine
' input
' xl = lower bound of search interval
' xu = upper bound of search interval
' tol = convergence criteria
' maxiter = maximum number of iterations allowed
' output
' xroot = real root of f(x) = 0
' froot = function value
' niter = actual number of iterations
' note: requires sub hohmfunc
local beps, a, b
local c, d, e
local fa, fb, fcc
local tol1, xm, p
local q, r, s
local xmin, tmp
beps = 2.2e-16
e = 0.0
a = xl
b = xu
hohmfunc(a, fa)
hohmfunc(b, fb)
fc = fb
niter = 0
for iter = 1 to maxiter
' count number of iterations
niter = niter + 1
if (fb * fc > 0.0) then
c = a
fc = fa
d = b - a
e = d
end if
if (abs(fc) < abs(fb)) then
a = b
b = c
c = a
fa = fb
fb = fc
fc = fa
end if
tol1 = 2.0 * beps * abs(b) + 0.5 * tol
xm = 0.5 * (c - b)
if (abs(xm) <= tol1 or fb = 0) then exit for
if (abs(e) >= tol1 and abs(fa) > abs(fb)) then
s = fb / fa
if (a = c) then
p = 2.0 * xm * s
q = 1.0 - s
else
q = fa / fc
r = fb / fc
p = s * (2.0 * xm * q * (q - r) - (b - a) * (r - 1.0))
q = (q - 1.0) * (r - 1.0) * (s - 1.0)
end if
if (p > 0) then q = -q
p = abs(p)
xmin = abs(e * q)
tmp = 3.0 * xm * q - abs(tol1 * q)
if (xmin < tmp) then xmin = tmp
if (2.0 * p < xmin) then
e = d
d = p / q
else
d = xm
e = d
end if
else
d = xm
e = d
end if
a = b
fa = fb
if (abs(d) > tol1) then
b = b + d
else
b = b + sgn(xm) * tol1
end if
hohmfunc(b, fb)
next iter
froot = fb
xroot = b
end sub
Lou
Posted: 05:57am 16 Mar 2017
This could make a SUPER lunar lander game for Einstein.....
Or maybe Geoff, matherp, or Kiiid.
Lou
