Local Time 21:20 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Getting Started .... Tera Term
kermess
Posted: 07:40am 13 Mar 2017
Good afternoon.
In the user manual "Getting Started With the Micromite", right on page 12
There is an image of the use of Tera Term and it is in color.
Question: it is really possible to use the micromite editor with Tera Term and in color or simply that image is a montage to demonstrate the different colors.
In the case that is real, that is to say that there are colors which is the configuration of Tera Term.
I've been looking at TBS and I have not seen anything.
It may be possible, but I have not been able to configure it.
Thank you very much.
Saludos.
David
twofingers
Posted: 07:45am 13 Mar 2017
  kermess said   In the case that is real, ...
Hi David,
it's real! VT100!
Michael
From Micromite User Manual MMBasic Ver 5.2 Beta 2 Page 64
  Quote  OPTION COLOURCODE ON
or
OPTION COLOURCODE OFF
Turn on or off colour coding for the editor's output. Keywords will be in
cyan, numbers in red, etc. The default is off.
Notes:
 This setting is saved in flash memory and is applied on startup.
 Colour coding requires a terminal emulator that can interpret the
appropriate escape codes. It works correctly with Tera Term however
Putty needs its default background colour to be changed to white.
 If colour coding is used it is recommended that the baud rate for the
serial console be set to a high speed.
 The keyword COLORCODE (USA spelling) can also be used.
From Micromite User Manual MMBasic Ver 5.2 Beta 2 Page 4
  Quote  A full screen editor is built into the Micromite. This only requires a VT100 terminal emulator and can
edit the whole program in one session. It includes advanced features such as colour coded syntax, search
and copy, cut and paste to and from a clipboard.
Edited by twofingers 2017-03-14
kermess
Posted: 08:09am 13 Mar 2017
Hi Michael
Thank you very much, the operation is correct.
Always have to read a little more ......
And I looking for the solution in Tera Term when it is in MicroMite.
Regards.
David
twofingers
Posted: 08:43am 13 Mar 2017
You are welcome!
