flip Senior Member
| Posted: 01:15am 12 Mar 2017 |
Copy link to clipboard |
 Print this post |
Hi all! Hope its OK to put a game here. Memory game I developed for uM Backpack Feb last year and tried it on MX470 with different resolution and it worked straight away (I surprised myself) so I thought it must be robust enough to share. I got idea of using MM.VRES and MM.HRES (and probably much more than I remember) from some of Geoff's snippets. It is a bit 'sledgehammer' in places and grossly lacking in comments but I hope it has some useful ideas!
It kept my 7yo niece amused for a whole 7 minutes (no mean feat these days) Enjoy.
option base 1 CONST LANDSCAPE = MM.HRes > MM.VRes const MAX_LEVEL = 10 dim pairs( MAX_LEVEL + LANDSCAPE, MAX_LEVEL + not(LANDSCAPE) ) as integer dim integer lvl = 1 dim lvlColour as integer dim lvlTextScale as integer dim as integer cf=rgb(yellow),ck=RGB(BLUE),cb=RGB(WHITE),ci=rgb(0,128,228),xo=10,yo=10 const gap=4 do 'Forever loop lvl=lvl + 1 GetLevel restore LevelConfigData for i=1 to lvl read lvlColour,lvlTextScale next i if LANDSCAPE then ny=lvl nx=ny+1 ELSE nx=lvl ny=nx+1 endif xstep=MM.HRes\nx ystep=MM.VRes\ny success%=0 'Populate values array v$="" for i=1 to nx*ny/2 v$=v$ + chr$(i) + chr$(i) '11223344.... next i 'Draw boxes and assign values CLS for x=1 to nx for y=1 to ny rbox gap+(x-1)*xstep,gap+(y-1)*ystep,xstep-gap,ystep-gap,,rgb(white),lvlColour 'Assign random value p%=int(rnd(1) * len(v$)) + 1 pairs(x,y)= ASC(mid$(v$, p%,1)) ' and remove it from list v$ = left$(v$,p%-1) + mid$(v$,p%+1) next y next x ' Game Loop do 'Get first selection do GetTouch xa=xp\xstep + 1 ya=yp\ystep + 1 loop while pairs(xa,ya)=0 'if 0, already matched Text gap\2+(xa-.5)*xstep,gap\2+(ya-.5)*ystep,str$(pairs(xa,ya)),cm,1,lvlTextScale,RGB(BLACK),lvlColour GetTouch xb=xp\xstep + 1 yb=yp\ystep + 1 if pairs(xb,yb) > 0 then Text gap\2+(xb-.5)*xstep,gap\2+(yb-.5)*ystep,str$(pairs(xb,yb)),cm,1,lvlTextScale,RGB(BLACK),lvlColour endif if pairs(xa,ya) = pairs(xb,yb) and (xa<>xb or ya<>yb) then success%=success%+1 ' register success for this pair pairs(xa,ya)=0 pairs(xb,yb)=0 ELSE ' show it for half a second pause 500 'incorrect choice - redraw background for both rbox gap+(xa-1)*xstep,gap+(ya-1)*ystep,xstep-gap,ystep-gap,,rgb(white),lvlColour if pairs(xb,yb)>0 then rbox gap+(xb-1)*xstep,gap+(yb-1)*ystep,xstep-gap,ystep-gap,,rgb(white),lvlColour endif endif loop while success% < nx*ny/2 kup%=0:e%=0 do if e% then RBOX 20,150,280,70,14,cb,cb:RBOX 23,153,274,64,11,ck,ck:text 35,160,"YIPPEE!",,1,4,cf,ck else RBOX 20,150,280,70,14,cb,cb:RBOX 23,153,274,64,11,cf,cf:text 35,160,"YIPPEE!",,1,4,ck,cf endif for i=1 to 30 pause 10 if Touch(x) = -1 then kup%=1 else if kup%=1 then exit do endif endif next i e%=not(e%) loop loop ' ********** SUBROUTINES ************ ' Wait for screen touch and Get Touch position into xp and yp sub GetTouch xp=0 yp=0 Do a=Touch(x) b=Touch(y) If (a>-1 And (a>xp+10) Or a<xp-10)) Or (b>-1 And (b>yp+10 Or b<yp-10)) Then If a>-1 And b>-1 Then 'Print a,b xp=a yp=b EndIf EndIf Loop while xp=0 or yp=0 or a>-1 or b>-1 end sub sub GetLevel() ' Returns 0 to exit or 1-MAX_LEVEL as chosen level cls local Msg as string 'Foreground, BacKground, Border and Inactive colours,xoffset,yoffset CLS 'Show level as separate box 'RBOX 55,20,232,70,14,cb,cb:RBOX 58,23,226,64,11,ci,ci:text 60,30," 5 x 6",,1,4,cf,ci 'or show as grouping box RBOX xo,yo,285,105,14,cb,cb:RBOX xo+3,yo+3,279,99,11,ci,ci ' Up Arrow RBOX xo+7,yo+7,42,42,12,cb,cb:RBOX xo+9,yo+9,38,38,10,ck,ck circle xo+28,yo+29,10,1,1,cf,cf:circle xo+23,yo+32,7,1,1,cf,cf:circle xo+33,yo+32,7,1,1,cf,cf:circle xo+28,yo+23,7,1,1,cf,cf:circle xo+18,yo+35,4,1,1,cf,cf:circle xo+38,yo+35,4,1,1,cf,cf:circle xo+28,yo+17,4,1,1,cf,cf PIXEL xo+20,yo+39,cf:pixel xo+36,yo+39,cf:pixel xo+20,yo+24,cf:pixel xo+36,yo+24,cf:pixel xo+23,yo+19,cf:pixel xo+33,yo+19,cf 'Down arrow RBOX xo+7,yo+55,42,42,12,cb,cb:RBOX xo+9,yo+57,38,38,10,ck,ck circle xo+28,yo+75,10,1,1,cf,cf:circle xo+23,yo+72,7,1,1,cf,cf:circle xo+33,yo+72,7,1,1,cf,cf:circle xo+28,yo+81,7,1,1,cf,cf:circle xo+18,yo+69,4,1,1,cf,cf:circle xo+38,yo+69,4,1,1,cf,cf:circle xo+28,yo+87,4,1,1,cf,cf PIXEL xo+20,yo+65,cf:pixel xo+36,yo+65,cf:pixel xo+20,yo+80,cf:pixel xo+36,yo+80,cf:pixel xo+23,yo+85,cf:pixel xo+33,yo+85,cf 'Go RBOX 100,150,120,70,14,cb,cb:RBOX 103,153,114,64,11,ck,ck:text 115,160,"GO!",,1,4,cf,ck do Msg=" "+str$(lvl)+" x "+str$(lvl+1) text xo+58,yo+24,Msg,,1,4,cb,ci GetTouch if xp>=xo and xp<=50+xo and yp>=yo and yp<=yo+100 then ' this is up or down if yp<yo+50 then lvl=lvl-1 if lvl<1 then lvl=1 else lvl=lvl+1 if lvl>8 then lvl=8 endif elseif xp>=100 and xp<=220 and yp>=150 and yp<=220 then ' this is GO button exit do endif loop end sub 'CLS:RBOX 2,6,285,105,14,cb,cb:RBOX 5,9,279,99,11,ck,ck:text 60,30,"Level 5",,1,4,cf,ci:RBOX 9,13,42,42,14,cb,cb:RBOX 11,15,38,38,12,ck,ck:RBOX 9,61,42,42,14,cb,cb:RBOX 11,63,38,38,12,ck,ck LevelConfigData: DATA 65535,15 'Cyan (full blue + green DAta 16711680,8 '9 causes artefacts Red data 16776960,5 '6 causes artefacts Yellow (Full Red + Green) data 16711935,3 '4 causes artefacts Magenta (Pink = full red and blue) data 65280,3 'Green data 16777215,2 'White data 255,2 'Blue ' data 16744448,1 'Burnt red data 8388479,1 ' Bright Green (full Green + 50% red and blue) ' data 8355711,1 ' Grey (50%) ' data 16777087,1 ' Light Brown/orange? (Full Red and Green + 50% blue
Requires touch, and the only way to exit is reset button or break key (if enabled)
Please let me know if you have any problems with it. If anyone is really interested, I will tidy up a lot more (e.g. better scalable fonts related to resolution, more detailed comments and exit-ability) and re-post Regards, PhilEdited by flip 2017-03-13 |
