Local Time 21:20 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : More then one TEMPR START?
Posted: 11:51pm 10 Mar 2017
Is there any way to have more then one of these?
The one works well, but if you have several sensors to check, in a GUI program you can't really be waiting around for 200ms while each sensor is checked.
That's where TEMPR START comes in, and it works great, but it won't allow you to have more then one at a time. If you try to start more then one sensor, you get an error message. This creates a problem in that you can read ONE in the background, but all the others force the code to wait for 200mS(or 100mS if you use the zero option), during which time, touch on the LCD is ignored. It is quite easy to trip up the GUI because of the long wait for the 18B20's - even if you space them out in the main loop(s).
Is there any way to do more then one?
Any plans to add this ability?
For now, I am simply not using two of three sensors, preferring to concentrate on the main system sensor for the fansink - it gets the priority for now.
Phil23
Posted: 12:38am 11 Mar 2017
Dunno Grog,
I've got 6 & 8 DS18B20's on my 2 MM's but I don't use Temp().
They are all on the same pin & I send the command for them to initialise etc,
then read them consecutively.
Those functions are in a thread somewhere.
Could do with that last bit of polishing though.
Initialise them.
[Code] '========================OneWire Temperature Functions=========================
'Sub Initialises all DS18B20 Sensors on the Bus
'The below will set the resolution
'Onewire Write PinTmp, 2, 5, &HCC, &H4E,&H00,&H00,&HXX
' 9 bit=0.5 :1f - 93.75ms
'10 bit=0.250 :3f - 187.5ms
'11 bit=0.125 :5f - 375.0ms
'12 bit=0.0625:7f - 750.0ms
Sub InitTemp
Onewire Write PinTmp, 2, 5, &HCC, &H4E,&H00,&H00,&H7F 'Set the Resolution of all Sensors
OneWire Write PinTmp, 1, 2, &HCC, &H44 'Start Conversion on all Sensors
[/code]
Read them.
[Code]'Function Returns the Termerature for the Serial# passed.
Function ReadTemp(TsSerial As Integer) As Float
Ts1=(TsSerial >> 48) and &hFF : Ts2=(TsSerial >> 40) and &hFF : Ts3=(TsSerial >> 32) and &hFF
Ts4=(TsSerial >> 24) and &hFF : Ts5=(TsSerial >> 16) and &hFF : Ts6=(TsSerial >> 8) and &hFF : Ts7=(TsSerial) and &hFF
'OneWire Write PinTmp, 1, 10, &H55,&H28,Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,&H44
'Check sensor is ready
Timer=0 : Status=0
If Timer > 1000 Then Error "Sensor Error"
OneWire Read PinTmp,4,1,Status ' Conversion status
Loop Until Status = 1
' Do
' 'Just pause for a second
' Loop Until Timer>1000
OneWire Write PinTmp,1,10, &H55,&H28,Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,&HBE
OneWire Read PinTmp, 2, 2, LTemp, HTemp
'Calculate the Temp in C
ReadTemp=((HTemp And &b111) * 256 + LTemp) / 16
' If HTemp And &b1000 Then ReadTemp=-ReadTemp 'Adjust if negative
If HTemp And &b1000 Then ReadTemp=(ReadTemp-128) 'Adjust if negative
' Print ReadTemp
' Print HTemp,LTemp
' Print Bin$(HTemp,8),Bin$(LTemp,8)
End Function
[/code]
Phil.
Edit:-
Other bits are,
[Code] 'Sensor Serial Numbers
Dim Integer TsAmb=&HFFA667A815016F 'Sensor0 Ambient Air Temp
Dim Integer TsCur=&H74413C0700005E 'Sensor1 Water Temp
Dim Integer TsInp=&HBF4C3B07000053 'Sensor2 Panel Input Temp
'Dim Integer TsOut=&H901C3B07000054 'Sensor3 Panel Output Temp FAILED & Changed.
Dim Integer TsOut=&H1D854A07000097 'Sensor3 Panel Output Temp
Dim Integer TsPan=&H28123D07000059 'Panel Temp[/code]
[Code]Sub ReadSensors
if timer>5000 then
RBOX 0,209,40,30,4,,RGB(Red) 'Set Left Status LED to Red whilst reading temps
TmpAmb=ReadTemp(TsAmb)
TmpCur=ReadTemp(TsCur)
TmpInp=ReadTemp(TsInp)
TmpOut=ReadTemp(TsOut)
TmpPan=ReadTemp(TsPan)
ReadSolar
Timer=0
RBOX 0,209,40,30,4,,RGB(Gray)
Endif
[/code]
Catch is needing to code the serial#'s.
Edited by Phil23 2017-03-12
Phil23
Posted: 12:54am 11 Mar 2017
Wonder if you could send this to each different pin and then just use Temp() if you have them on different pins.
Then you don't need to go down the serial# road.
[Code]'========================OneWire Temperature Functions=========================
Sub InitTemp
End Sub[/code]
Phil.Edited by Phil23 2017-03-12
disco4now
Posted: 02:55am 11 Mar 2017
I think you could used SETTICK 300, ReadTemps,4
The ReadTemps SUB would have say three/six states kept track of with a global variable.
Each time its called it will do either a TEMP START or a TEMPR for the 18B20's in a round robin type of thing. As it only does one of TEMP START or TEMPR is is never blocking and hands back control immediately.
State 1 TEMP START 18B20 No1
State 2 TEMPR No 1 and set flag to say it updated
State 3 TEMP START 18B20 No2
State 4 TEMPR No 2 and set flag to say it updated
State 5 TEMP START 18B20 No3
State 6 TEMPR No 3 and set flag to say it updated
They would sequentially complete in background with minimal effect on the main loop.
Gerry
F4 H7FotSF4xGT
Posted: 04:51am 11 Mar 2017
Brilliant suggestion Gerry, I was scrolling to the bottom of the thread to say a similar thing but you had beaten me to it.
Posted: 06:14am 11 Mar 2017
What is the reason for only allowing one TEMPR START at a time?
I thought one of the major reasons for the DS18B20 having the start feature built in was so that multiple sensors could be started (as they apparently can with OneWire), and then read quickly after the appropriate time had passed.
That's to say that I thought that whatever TEMPR START would do was "fire and forget" for the pin involved, so that multiple ones on different pins would not be blocked.
Edited by lizby 2017-03-12
Paul_L
Posted: 08:04am 11 Mar 2017
What will happen if I have multiple DS18B20 sensors but they are each connected to different pins?
I was planning on starting them all in a loop then going back and reading them all in a second loop. I will be using an array to hold the pin numbers and the data collected. The code will look something like this.
WaitEnd%=TIMER + 800
for i=1 to 19 ' start 19 sensors
TEMPR START Td(i,2),3 ' Td(n,2) contains the pin number
next i
DO : LOOP UNTIL (TIMER > WaitEnd%)
for i=1 to 19 ' read 19 sensors
Zd(i,1)= (TEMPR(Zd(i,2))*9/5)+32 ' Td(n,1) contains the temp data
next i
Will this work or will the second pass through the START loop return an error?
Paul_L
Phil23
Posted: 03:15pm 11 Mar 2017
  Geoffg said   Brilliant suggestion Gerry, I was scrolling to the bottom of the thread to say a similar thing but you had beaten me to it.
Slight tangent Geoff,
But can you explain what TEMPR START does in low level terms?
I presuming it's doing a bit more than just these 2 commands, like maintains some other status etc.
[/code] Onewire Write PinTmp, 2, 5, &HCC, &H4E,&H00,&H00,&H7F 'Set the Resolution of all Sensors
[/code]
Could help me improve my approach.
Phil.
Posted: 04:54pm 11 Mar 2017
The DS18B20 is a difficult thing to work with because you have to start the conversion and then wait a considerable time (in microcontroller terms) for it to finish the conversion THEN you can read the temperature. The original TEMPR() function just sat there twiddling its thumbs in a loop waiting for a specific number of microseconds for the conversion to finish. My thinking was that this would not be a problem because you only needed to measure temperature every few minutes. However, locking up the interpreter even once a minute did turn out to be a problem.
TEMPR START was the answer to this. What it does is send the start command to the DS18B20 then starts a counter running. Later, when the TEMPR() function is called it just checks the counter and if it has reached the allocated time it will request the temperature from the DS18B20. If the counter is still running it will wait for it to finish before requesting the temperature.
Because background counters soak up CPU time I only implemented one counter for the DS18B20 timer (so Paul_L your program would not work). I could have implemented more but then all users of the Micromite would suffer a small performance penalty as every microsecond MMBasic would have to check a number of counters to see if they needed to be updated, even if the TEMPR command had not been used.
Measuring temperature using the DS18B20 has been far more popular than I anticipated so something better is needed. You can query the DS18B20 to tell if it is busy and that would be the ideal solution - the TEMPR() function could do that and no counters would be needed. I had trouble getting this to work reliably last time but it is worth further investigation. Another possibility is to rewrite the code to use just one counter.
I'm heading off overseas again, this time to New Zealand (its a tough life ), and I will have a look at it when I get back - so there will be a fix sooner or later. While I am at it, I will have a look at implementing multiple sensors on the one wire - but that is messy and might not be practical.
P.S. If anyone lives around Taupo or Palmerston North let me know. We might be able to get together to say hello.
Paul_L
Posted: 06:12pm 11 Mar 2017
  Geoffg said  Because background counters soak up CPU time I only implemented one counter for the DS18B20 timer (so Paul_L your program would not work).
Well, that's a fine kettle of fish I've gotten into.
@Geoffg - I only need one counter since I'm starting all the sensors building a reading simultaneously and I can implement that easily enough with a loop. The 800 ms delay for the sensors to build an 11 bit return word is not a serious problem. Some of Phil's code seems to use lower level functions to start the DS18B20s building their return word. Do you think I should try to use Phil's method or should I await your return from NZ?
How was your trip to Canada?
Paul_L
Posted: 10:58pm 11 Mar 2017
Without going through your code in detail it seems that you are using native DS18B20 commands sent via the 1-wire functions. In that case none of my comments apply, they only apply to the TEMPR command and function. Note that you cannot mix the two.
Canada was great, went dog sledding, curling, snow shoeing, etc. Stuff that you cannot do in Oz.
Posted: 08:35am 12 Mar 2017
This is to confirm Phil23's suggestion that this can be done with onewire commands with one DS18B20 per pin (so no need to know the serial number).
After starting the conversion and pausing 1000ms (can be less depending on resolution sought), each read of the temperature takes about 10 or 11 milliseconds (including printing the result).
I did this with 3 DS18B20s using Grogster's sweet Explore-28 PCB, just arrived yesterday.
[code]
dim Temp1 as float, HTemp as integer, LTemp as integer
pause 1000
I2C open 100, 1000
pause 1000
print "temperatures from 3 DS18B20s using onewire start Commands"
for i = 1 to 5
' using Phil23 code, post 2: http://www.thebackshed.com/forum/forum_posts.asp?TID=9419&PN=1
' and from DaveC166 post 11: http://www.thebackshed.com/forum/forum_posts.asp?TID=6898
Onewire Write 2, 2, 5, &HCC, &H4E,&H00,&H00,&H7F 'Set the Resolution
OneWire Write 2, 8, 2, &HCC, &H44 'Start Conversion
Onewire Write 3, 2, 5, &HCC, &H4E,&H00,&H00,&H7F 'Set the Resolution
OneWire Write 3, 8, 2, &HCC, &H44 'Start Conversion
Onewire Write 4, 2, 5, &HCC, &H4E,&H00,&H00,&H7F 'Set the Resolution
OneWire Write 4, 8, 2, &HCC, &H44 'Start Conversion
print ""x
print " TIMER before pause = "+str$(timer)
pause 1000
print " TIMER after pause = "+str$(timer)
' print "Temp1 "+str$(DS18B20(2))+" TIMER="+str$(timer)
onewire write 2, 1, 2, &HCC, &HBE
onewire read 2, 2, 2, LTemp, HTemp
Temp1=((HTemp And &b111) * 256 + LTemp) / 16
If HTemp And &b1000 Then Temp1=(Temp1-128) 'Adjust if negative
print str$(i)+" Temp1 "+str$(Temp1)+" TIMER="+str$(timer)
onewire write 3, 1, 2, &HCC, &HBE
onewire read 3, 2, 2, LTemp, HTemp
print str$(i)+" Temp2 "+str$(Temp1)+" TIMER="+str$(timer)
onewire write 4, 1, 2, &HCC, &HBE
onewire read 4, 2, 2, LTemp, HTemp
print str$(i)+" Temp3 "+str$(Temp1)+" TIMER="+str$(timer)
pause 3000
next i
print "Done"
end
[/code]
Here's the output.
[code]
> run
TIMER before pause = 9612322
TIMER after pause = 9613329
1 Temp1 26 TIMER=9613339
1 Temp2 25.875 TIMER=9613349
1 Temp3 23.625 TIMER=9613360
TIMER before pause = 9616382
TIMER after pause = 9617388
2 Temp1 26 TIMER=9617398
2 Temp2 25.8125 TIMER=9617408
2 Temp3 23.625 TIMER=9617419
TIMER before pause = 9620441
TIMER after pause = 9621447
3 Temp1 25.9375 TIMER=9621457
3 Temp2 25.8125 TIMER=9621469
3 Temp3 23.625 TIMER=9621480
TIMER before pause = 9624501
TIMER after pause = 9625507
4 Temp1 25.875 TIMER=9625517
4 Temp2 25.8125 TIMER=9625528
4 Temp3 23.625 TIMER=9625539
TIMER before pause = 9628561
TIMER after pause = 9629567
5 Temp1 25.875 TIMER=9629577
5 Temp2 25.75 TIMER=9629588
5 Temp3 23.625 TIMER=9629599
Done
[/code]
Edited by lizby 2017-03-13
Posted: 08:48pm 13 Mar 2017
Hi Lance (and all),
Thanks for sharing this.
Just one little thing to make the 'timings' easier to read; can I simply suggest that you add TIMER=0 immediately before the line that prints the very first 'time' i.e. 'TIMER before pause....'
Great work . . .
WW
Posted: 05:14am 14 Mar 2017
WW--I like to keep TIMER as a free-running count of the number of milliseconds passed since the program started (with the understanding that with 4-byte integers it will overflow in 50 days).
In this example, setting TIMER=0 would make the output clearer, but in general, rather than TIMER=0, I like this construction in a loop:
endTime%=TIMER+delayTime%
IF TIMER => endTime% THEN
Lance
Edited by lizby 2017-03-15
