Forum Index : Microcontroller and PC projects : EGT.BAS problems
| oldtimer Newbie Joined: 02/12/2016 Location: AustraliaPosts: 18 |
Hi Peter Im trying to get your EGT gauge working on a 28 pin MM - running Ver 5.2 but am having no success so far- when I load the egt.bas file - the following error is returned " CPU exception #6 at address 0xA0001458 Processor restarted" >Im assuming that's because there is no MCP342 ADC or DS 18B20 attached or the code is not usable on an ILI 9341 LCD panel Would it be possible to provide a wiring diagram of how you connected the ADC and Temp sensor and the I/O pin numbers you used to get the gauge operating - my end plan is to use the gauge and associated code to indicate OAT in an aircraft Could you also tell me what that error actually means - I seem to get it a lot when attempting to run codes with c functions attached many thanks |
Don't know that file but I think you probably need an SSD1963 display and MM+. see this thread. Gauges Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Please provide a link to the thread/code you are talking about |
Hi Peter Many thanks for your reply The post I refer to is on page 3 of a set of poste relating to " searching for the perfect gauge" - your last post is dated 04 June 15 @1115 in that post you described an EGT gauge and an attached zip file - named 2015-06-04-111036 -EGT.ZIP and mentioned it was a fully functioning EGT I note it also requires the addition of an MCP342x and a DS18B20 temp sensor when I ran the unzipped file - I got the "cpu execption" error I mentioned in my first post could you tell me if its possible to use a 28 pin MM - VER 5.2 with ILI9341 backpack to run the code and achieve a functioning EGT gauge and also what the" cpu execption - processor restarted " errors mean Ive attached the code for your info many thanks Bill Winefield ' ' K-type thermocouple conversion using MCP342x ADC and DS18B20 for coldjunction compensation ' cpu 48 option explicit option default integer Const stepsize=1 const maxgauges=1 const maxtemp=1000 const mintemp=550 dim integer x(maxgauges), y(maxgauges), radius(maxgauges), fontsize(maxgauges) dim integer lastx1(maxgauges), lastx2(maxgauges), lastx3(maxgauges), lasty1(maxgauges), lasty2(maxgauges), lasty3(maxgauges) dim integer whitesec(maxgauges),greensec(maxgauges),yellowsec(maxgauges),redsec(maxgauges),blacksec(maxgauges) dim s$ const ADCBits16=&B10001000 const ADCbits16timeout= 15 'max voltages gain 8 = +/- 0.256V const signed=1 const unsigned=0 const zeroOffset=90 'the thermocouple table starts at -90 degrees C so we offset the table lookup by this ' Pin assignment const DS18B20pin=43 const ADCi2c = &B1101000 ' set to match your hardware, NB base address is same as DS1307 ' dim i as integer,coldjunction as integer,adccount as integer, coldjunctionequiv as integer,temperature as integer dim ktype(1090) as integer dim testvoltage as float ' INIT: i2c open 400,1000 i=ktable() 'read in the therocouple lookup table if i<>1 then end 'must be something wrong with the data table initgauge(0,mm.hres\2,mm.vres\2,mm.hres\2-5,1,-150,-150,105,105,150,"EGT",15) ' MAIN: do temperature=gettemp(0,DS18B20pin) 'ADC input pins shorted so should record cold junction temperature s$=str$(temperature,4) needle(0,max((temperature-550)*2\3-150,-150),rgb(white),s$) pause 500 loop end ' function max(a as integer, b as integer) AS INTEGER IF a> b then max= a else max=b endif ' END FUNCTION function gettemp(ADCchannel as integer, coldjunctionpin as integer) coldjunction=cint(ds18b20(coldjunctionpin)) coldjunctionequiv=ktype(coldjunction+zeroOffset)'get the number of ADC counts that the cold junction temperature would represent ' print "Coldjunction temperature is ",coldjunction," ADC equivalent is ",coldjunctionequiv adccount=readadcraw16x8(ADCchannel) 'Measure thermocouple voltage with gain of 8 and 16 bits to give adequate resolution adccount=adccount+coldjunctionequiv 'add in the cold junction temperature equivalent temperature=findadc(adccount) gettemp=temperature end function ' function findadc(adcnum as integer) 'just does a simple binary chop of the ADC count table to find the nearest entry local top as integer, bottom as integer, work as integer, test as integer top=1089 bottom=0 'set up search limits if ktype(1089)<adcnum then findadc=2000 'above range exit function endif if ktype(0)>adcnum then findadc=-2000 'below range exit function endif do while top>bottom+1 work=(top+bottom)\2 test=ktype(work) if test=adcnum then findadc=work-zerooffset end function endif if test> adcnum then top=work else bottom=work endif loop if (ktype(top)-adcnum)>=(adcnum-ktype(bottom)) then findadc=bottom-zerooffset else findadc=top-zerooffset endif end function ' function readadcraw16x8(channel as integer) ' config byte for chip is: ' bits 0 and 1 - Gain = 8 ' bits 2 and 3 - # of bits = 16; 15 samples per second respectively ' bit 4 - 0=one-shot conversion ; we will always use 0 to allow changes to config e.g. which channel ' bits 5 and 6 - channel number 0-3 ' bit 7 - set to start conversion, wait for clear to indicate conversion end ' max voltage for gain 8 = +/- 0.256V local channelmask as integer,gainmask as integer, scratch as integer, timeout as integer local configbyte as integer local ADCret$ length 4 if channel<0 or channel>3 then readadcraw16x8=100000000 'impossible value exit function endif gainmask=3 'Gain of 8 timeout=ADCbits16timeout configbyte=ADCbits16 or gainmask channelmask=channel << 5 configbyte=configbyte or channelmask i2c write ADCi2c, 0,1,configbyte do pause 5 i2c read ADCi2c, 0,4,ADCret$ scratch =asc(right$(ADCret$,1)) AND &B10000000 timeout=timeout-1 loop until (scratch=0) or (timeout=0) if timeout <>0 then readadcraw16x8=intconv(left$(ADCret$,2),signed) else readadcraw16x8=200000000 'impossible value endif' end function ' function ktable() ' This table gives the ADC counts at 16 bits resolution and gain of 8 for every temperature from -90 to 1000 degrees C data 65121,65125,65129,65133,65137,65141,65146,65150,65154,65158, 65162,65166,65171,65175,65179,65183,65188,65192,65196,65201, 65205,65209,65214,65218,65222,65227,65231,65236,65240 data 65244,65249,65253,65258,65262,65267,65271,65276,65281,65285, 65290,65294,65299,65303,65308,65313,65317,65322,65326,65331, 65336,65341,65345,65350,65355,65359,65364,65369,65374 data 65378,65383,65388,65393,65398,65402,65407,65412,65417,65422, 65427,65432,65436,65441,65446,65451,65456,65461,65466,65471, 65476,65481,65486,65491,65496,65501,65506,65511,65516,65521, 65526,65531 data 0,5,10,15,20,25,30,35,41,46,51,56,61,66,71,76,82,87,92,97,102,107,113,118,123,128,133,138,144,149,154,159,164,170 data 175,180,185,191,196,201,206,212,217,222,227,233,238,243,248, 254,259,264,270,275,280,285,291,296,301,307,312,317,322,328, 333,338,344,349,354,360 data 365,370,376,381,386,392,397,402,408,413,418,423,429,434,439, 445,450,455,461,466,471,477,482,487,493,498,503,508,514,519, 524,530,535,540,546,551,556,561,567,572 data 577,582,588,593,598,604,609,614,619,625,630,635,640,646,651, 656,661,666,672,677,682,687,692,698,703,708,713,718,724,729, 734,739,744,750,755,760,765,770,775,781 data 786,791,796,801,806,811,817,822,827,832,837,842,847,852,858, 863,868,873,878,883,888,894,899,904,909,914,919,924,929,934, 940,945,950,955,960,965,970,975,980,985 data 991,996,1001,1006,1011,1016,1021,1026,1032,1037,1042,1047,1052,1057,1062,1067,1072,1078,1083,1088,1093,1098,1103,1108,11 13,1119,1124,1129,1134,1139,1144,1149,1155,1160,1165,1170,1175,1180,1186 data 1191,1196,1201,1206,1211,1217,1222,1227,1232 data 1237,1242,1248,1253,1258,1263,1268,1274,1279,1284,1289,1294 data 1300,1305,1310,1315,1320,1326,1331,1336,1341,1347,1352,1357, 1362,1368,1373,1378,1383,1389,1394,1399,1404,1410,1415,1420, 1425,1431,1436,1441,1446,1452,1457,1462,1468,1473,1478,1483, 1489,1494,1499,1504 data 1510,1515,1520,1526,1531,1536,1542,1547,1552,1557,1563,1568, 1573,1579,1584,1589,1594,1600,1605,1610,1616,1621,1626,1632, 1637,1642,1648,1653,1658,1664,1669,1674,1680,1685,1690,1696, 1701,1706,1712,1717 data 1722,1728,1733,1738,1744,1749,1754,1760,1765,1771,1776,1781, 1787,1792,1797,1803,1808,1813,1819,1824,1830,1835,1840,1846, 1851,1856,1862,1867,1873,1878,1883,1889,1894,1899,1905,1910, 1916,1921,1926,1932 data 1937,1942,1948,1953,1959,1964,1969,1975,1980,1985,1991,1996, 2002,2007,2012,2018,2023,2029,2034,2039,2045,2050,2056,2061, 2066,2072,2077,2083,2088,2093,2099,2104,2110,2115,2120,2126, 2131,2137,2142,2148 data 2153,2158,2164,2169,2175,2180,2185,2191,2196,2202,2207,2212, 2218,2223,2229,2234,2240,2245,2250,2256,2261,2267,2272,2278, 2283,2289,2294,2299,2305,2310,2316,2321,2327,2332,2337,2343, 2348,2354,2359,2365 data 2370,2375,2381,2386,2392,2397,2403,2408,2414,2419,2424,2430, 2435,2441,2446,2452,2457,2463,2468,2473,2479,2484,2490,2495, 2501,2506,2512,2517,2522,2528,2533,2539,2544,2550,2555,2561, 2566,2572,2577,2582 data 2588,2593,2599,2604,2610,2615,2621,2626,2632,2637,2642,2648, 2653,2659,2664,2670,2675,2681,2686,2692,2697,2702,2708,2713, 2719,2724,2730,2735,2741,2746,2752,2757,2762,2768,2774,2779, 2784,2790,2795,2801 data 2806,2812,2817,2823,2828,2834,2839,2844,2850,2855,2861,2866, 2872,2877,2883,2888,2894,2899,2904,2910,2915,2921,2926,2932, 2937,2943,2948,2954,2959,2964,2970,2975,2981,2986,2992,2997, 3003,3008,3014,3019 data 3025,3030,3035,3041,3046,3052,3057,3063,3068,3074,3079,3084, 3090,3095,3101,3106,3112,3117,3123,3128,3133,3139,3144,3150, 3155,3161,3166,3172,3177,3182,3188,3193,3199,3204,3210,3215, 3220,3226,3231,3237 data 3242,3248,3253,3259,3264,3270,3275,3280,3286,3291,3297,3302, 3308,3313,3318,3324,3329,3335,3340,3345,3351,3356,3362,3367, 3373,3378,3383,3389,3394,3400,3405,3410,3416,3421,3427,3432, 3438,3443,3448,3454 data 3459,3465,3470,3475,3481,3486,3492,3497,3502,3508,3513,3519, 3524,3529,3535,3540,3546,3551,3556,3562,3567,3573,3578,3583, 3589,3594,3599,3605,3610,3616,3621,3626,3632,3637,3643,3648, 3653,3659,3664,3670 data 3675,3680,3686,3691,3696,3702,3707,3712,3718,3723,3729,3734, 3739,3745,3750,3755,3761,3766,3771,3777,3782,3787,3793,3798, 3804,3809,3814,3820,3825,3830,3836,3841,3846,3852,3857,3862, 3868,3873,3878,3884 data 3889,3894,3900,3905,3910,3916,3921,3926,3932,3937,3942,3948, 3953,3958,3963,3969,3974,3979,3985,3990,3995,4001,4006,4011, 4017,4022,4027,4033,4038,4043,4048,4054,4059,4064,4070,4075, 4080,4085,4091,4096 data 4101,4106,4112,4117,4122,4128,4133,4138,4143,4149,4154,4159, 4165,4170,4175,4180,4186,4191,4196,4201,4207,4212,4217,4222, 4228,4233,4238,4243,4249,4254,4259,4264,4270,4275,4280,4285, 4291,4296,4301,4306 data 4312,4317,4322,4327,4333,4338,4343,4348,4354,4359,4364,4369, 4374,4380,4385,4390,4395,4401,4406,4411,4416,4421,4426,4432, 4437,4442,4447,4453,4458,4463,4468,4473,4479,4484,4489,4494, 4499,4505,4510,4515 data 4520,4525,4530,4536,4541,4546,4551,4556,4562,4567,4572,4577, 4582,4587,4593,4598,4603,4608,4613,4618,4623,4629,4634,4639, 4644,4649,4654,4660,4665,4670,4675,4680,4685,4690,4696,4701, 4706,4711,4716,4721 data 4726,4732,4737,4742,4747,4752,4757,4762,4767,4773,4778,4783, 4788,4793,4798,4803,4808,4814,4819,4824,4829,4834,4839,4844, 4849,4854,4860,4865,4870,4875,4880,4885,4890,4895,4900,4905, 4910,4915,4921,4926 data 4931,4936,4941,4946,4951,4956,4961,4966,4971,4976,4982,4987, 4992,4997,5002,5007,5012,5017,5022,5027,5032,5037,5042,5047, 5052,5057,5062,5068,5073,5078,5083,5088,5093,5098,5103,5108, 5113,5118,5123,5128 data 5133,5138,5143,5148,5153,5158,5163,5168,5173,5178,5183,5188, 5193,5198,5203,5208,5213,5218,5223,5228,5233,5238,5243,5248, 5253,5258,5263,5268,5273,5278 Local i,j j=-420 ' 5 less than lowest value in the table ktable=1 for i= 0 to 1089 read ktype(i) if ktype(i)>32767 then ktype(i)=ktype(i)-65536 if (ktype(i)-j) <4 or (ktype(i)-j) >7 then ktable=0 'check no errors in table j=ktype(i) next i end function ' Sub segment(x As integer, y As integer, outsize As integer, startradial As integer, endradial As integer, col As integer, insize as integer ) Local integer i,j,x1,x2,y1,y2,sr,er,xx0(1),yy0(1),xx1(1),yy1(1),xx2(1),yy2(1),tcol(1) If startradial=endradial Then x2=Sin(Rad(startradial))*outsize + x y2=-Cos(Rad(startradial))*outsize + y x1=Sin(Rad(startradial))*insize + x 'insize is 0 if not specified so a complete line from the centre is drawn y1=-Cos(Rad(startradial))*insize + y Line x1,y1,x2,y2,,col Else If startradial<endradial Then sr=startradial er=endradial Else er=startradial sr=endradial EndIf For i=sr+stepsize To er Step stepsize x2=Sin(Rad(i))*outsize + x y2=-Cos(Rad(i))*outsize + y x1=Sin(Rad(i-stepsize))*outsize + x y1=-Cos(Rad(i-stepsize))*outsize + y xx0(0)=x yy0(0)=y xx1(0)=x1 yy1(0)=y1 xx2(0)=x2 yy2(0)=y2 tcol(0)=col j=triangles(1,xx0(),yy0(),xx1(),yy1(),xx2(),yy2(),tcol()) Next i EndIf End Sub ' sub initgauge(gaugeindex% , xpos%, ypos%, gsize%, fontmult%, whitestart%, greenstart%, yellowstart%, redstart%, blackstart%, displaystring$, tickspace%) local ticks% Circle xpos%,ypos%,gsize%+3,0,,RGB(210,210,210),RGB(210,210,210) 'background to create the bezel segment(xpos%,ypos%,gsize%,whitestart%,greenstart%, RGB(white),0) segment(xpos%,ypos%,gsize%,greenstart%,yellowstart%, RGB(green),0) segment(xpos%,ypos%,gsize%,yellowstart%,redstart%, RGB(yellow),0) segment(xpos%,ypos%,gsize%,redstart%,blackstart%, RGB(red),0) segment(xpos%,ypos%,gsize%,blackstart%,whitestart%+360, 0) segment(xpos%,ypos%,gsize%,greenstart%,greenstart%, 0) segment(xpos%,ypos%,gsize%,yellowstart%,yellowstart%, 0) segment(xpos%,ypos%,gsize%,redstart%,redstart%, 0) if tickspace% then for ticks%=whitestart% to blackstart% step tickspace% segment(xpos%,ypos%,gsize%,ticks%,ticks%, 0, (gsize%*19)\20) next ticks% endif Circle xpos%,ypos%, (gsize%*4)\5,0,,0,0 text xpos%-len(displaystring$)*4*fontmult%,ypos%+gsize%-fontmult%*28,displaystring$ ' string centred in black segment x(gaugeindex%)=xpos% y(gaugeindex%)=ypos% radius(gaugeindex%)=gsize% fontsize(gaugeindex%)=fontmult% lastx1(gaugeindex%)=xpos% lastx2(gaugeindex%)=xpos%+2 lastx3(gaugeindex%)=xpos%+2 lasty1(gaugeindex%)=ypos% lasty2(gaugeindex%)=ypos%+2 lasty3(gaugeindex%)=ypos% whitesec(gaugeindex%)=whitestart% greensec(gaugeindex%)=greenstart% yellowsec(gaugeindex%)=yellowstart% redsec(gaugeindex%)=redstart% blacksec(gaugeindex%)=blackstart% end sub ' ' Routine to draw a pointer ' Parameters are: ' gaugeindex ' radial of pointer to be drawn (0-360 degrees) ' colour to draw pointer ' Sub needle(gaugeindex as integer, angle As integer, col As integer, value$ as string) Local integer x1,y1,x2,y2,x3,y3,x4,y4,j, xx1(1),yy1(1),xx2(1),yy2(1),xx3(1),yy3(1), tcol(1), size size= (radius(gaugeindex)*4)\5-1 x1=Sin(Rad(angle-90))*size/10 + x(gaugeindex) y1=-Cos(Rad(angle-90))*size/10 + y(gaugeindex) x2=Sin(Rad(angle))*size + x(gaugeindex) y2=-Cos(Rad(angle))*size + y(gaugeindex) x3=Sin(Rad(angle+90))*size/10 + x(gaugeindex) y3=-Cos(Rad(angle+90))*size/10 + y(gaugeindex) xx1(0)=lastx1(gaugeindex) yy1(0)=lasty1(gaugeindex) xx2(0)=lastx2(gaugeindex) yy2(0)=lasty2(gaugeindex) xx3(0)=lastx3(gaugeindex) yy3(0)=lasty3(gaugeindex) xx1(1)=x1 yy1(1)=y1 xx2(1)=x2 yy2(1)=y2 xx3(1)=x3 yy3(1)=y3 tcol(0)=0 tcol(1)=col j=triangles(2,xx1(),yy1(),xx2(),yy2(),xx3(),yy3(),tcol()) Circle x(gaugeindex),y(gaugeindex),size\10,0,,col,col) Circle x(gaugeindex),y(gaugeindex),size\15,0,,0,0 Circle x(gaugeindex),y(gaugeindex),size\20,0,,RGB(240,240,240),RGB(240,240,240) lastx1(gaugeindex)=x1 lastx2(gaugeindex)=x2 lastx3(gaugeindex)=x3 lasty1(gaugeindex)=y1 lasty2(gaugeindex)=y2 lasty3(gaugeindex)=y3 text x(gaugeindex)-len(value$)*4*fontsize(gaugeindex)-3*fontsize(gaugeindex),y(gaugeindex)+radius(gaugeindex)-fontsize(gaugei ndex)*16,value$ ' string centred in black segment End Sub CFunction intconv 'convert data read from i2c to integer including extending sign bit across the 64 bit integer 00000000 27bdfff8 00001021 00001821 afa20000 afa30004 90880000 1900000b 01003821 2503ffff 03a31821 24020001 00823021 90c60000 a0660000 24420001 00e2302a 10c0fffa 2463ffff 8ca20000 1040000d 03a81021 9042ffff 30420080 10400009 29020008 10400007 03a81021 27a40008 2403ffff a0430000 24420001 5444fffe a0430000 8fa20000 8fa30004 03e00008 27bd0008 End CFunction CFunction triangles 00000000 8c820004 27bdffa0 afbf005c afbe0058 afb70054 afb60050 afb5004c afb40048 afb30044 afb20040 afb1003c afb00038 afa40060 afa50064 afa60068 184000e7 afa7006c afa00030 3c179d00 8fa30030 8fa50068 8fa80070 000310c0 00a22021 01021821 8c840000 8c630000 8fa90064 afa40018 01223821 afa3001c 8fa40074 8fa3006c 8fa80078 8fa9007c 00623021 00822821 01022021 01221021 8fa80018 8fa9001c 8cc60000 8ca50000 0128182a 8cf30000 8c9e0000 afa60028 afa5002c 10600006 8c540000 02601021 afa90018 00c09821 afa8001c afa20028 8fa5001c 03c5102a 10400008 8fa90018 8fa20028 8fa8002c afbe001c afa80028 00a0f021 afa2002c 8fa90018 8fa3001c 0069102a 10400008 8fa50018 8fa4001c 02601021 afa40018 8fb30028 afa9001c afa20028 8fa50018 10be007f 8fa3001c 107e009e 8fa40018 2463ffff 0064102a 1440002d 8fb00018 8fa80028 8fa9002c 8fa5001c 01134023 01334823 03c4a823 afbe0034 00a4b023 0280f021 afa80020 afa90024 00808021 00009021 00008821 0060a021 0236001a 02c001f4 8fa30024 8fa20020 02002821 02003821 02228821 26100001 00002012 0255001a 02a001f4 00932021 02439021 00003012 00d33021 00c4182a 10600003 00801021 00c02021 00403021 afbe0010 8ee20048 0040f809 00000000 0290102a 1040ffe6 00000000 03c0a021 8fbe0034 03d0102a 1440002f 8fa8001c 8fa90018 8fa4002c 8fa50028 0093a823 0085b023 02089023 02098823 03c91823 03c81023 72569002 72358802 afb40018 afb5001c afb60020 0260a821 00a0b021 00609821 0040a021 0254001a 028001f4 8fa3001c 8fa20020 02002821 02003821 02429021 26100001 00002012 0233001a 026001f4 00962021 02238821 00003012 00d53021 00c4182a 10600003 00801021 00c02021 00403021 8fa80018 afa80010 8ee20048 0040f809 00000000 03d0102a 1040ffe5 00000000 8fa90030 8fa20060 25290001 8c430004 000917c3 0043202a 1480ff5a afa90030 14620007 8fbf005c 8fa30060 8c620000 0122102b 5440ff54 8fa30030 8fbf005c 8fbe0058 8fb70054 8fb60050 8fb5004c 8fb40048 8fb30044 8fb20040 8fb1003c 8fb00038 03e00008 27bd0060 8fa80028 0113102a 14400023 02603821 0268102a 14400022 8fa70028 02603821 02602021 8fa9002c 0124102a 54400003 8fa4002c 00e9102a 0122380b 8fa20018 afb40010 00e23821 8fa50018 8ee20048 00803021 0040f809 00e43823 8fa90030 8fa20060 25290001 8c430004 000917c3 0043202a 1480ff28 afa90030 1000ffcd 00000000 0064102a 1040ff66 8fa80028 1000ff8f 8fb00018 1000ffe2 8fa40028 1000ffe0 02602021 1440ffca 8fbf005c 8c820000 5440ff17 afa00030 1000ffc6 8fbe0058 End CFunction 'MIPS32 M4Krom the code that it required the addition of |
This thread I think here John |
It should run fine on a 28-pin and ILI9341 but you must either have the various peripherals connected or spoof vaguely valid data. Otherwise you are calling C routines with data that is probably completely inappropriate that they can't deal with. Here is a Basic version of intconv that you can substitute that may make it easier to see what is happening. I suspect it is intconv causing the problem but you can check that with print statements and then pauses (to allow the text to output) before and after Function intconv(s$, p%) as integer local integer l,k,j,i=len(s$) k=peek(varaddr j) for l=1 to i poke byte k+i-l,asc(mid$(s$,l,1)) next l if p% then if (asc(left$(s$,1)) and &H80) then for l=i to 7 poke byte k+l,&HFF next l endif endif intconv=j End Function The various exception codes are given here but in general won't help you. |
