Local Time 20:24 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : var eeprom saving when reprogramming
Posted: 03:53am 06 Mar 2017
Is there a way to preserve the contents of the eeprom (VAR saved variables) when downloading a new program?
The manual says "saved variables will be automatically cleared by the NEW command or when a new program is loaded."
I often just want to make a small change in a program while preserving variable values saved in eeprom. Is there a way to do this?
jman
Posted: 08:22am 06 Mar 2017
Hi
Why not use the built in editor to make the small changes that way all VAR save variables will be intact
Jman
Posted: 08:36am 06 Mar 2017
bit more involved but it is easy to add a EEPROM or FRAM chip and then store your variables in that - safe from everything then.
Posted: 08:46am 06 Mar 2017
Yes, I have eeprom on a ds3132 module, and can use that, but would have to write the functional equivalent of var save and var restore.
Posted: 10:03am 06 Mar 2017
does this help?
http://www.thebackshed.com/forum/forum_posts.asp?TID=6917
Edited by CaptainBoing 2017-03-07
Posted: 11:53am 06 Mar 2017
Yes, I saw and noted that nice library. I was hoping for something like the PICAXE directive, "#no_data", which causes eeprom to be preserved when the program is re-flashed. Something like
OPTION SAVE EEPROM
