Local Time 22:20 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme: Text to Speech S.A.M
Posted: 08:56am 04 Mar 2017
Probably not remotely useful but fun nevertheless
Version 5.3.11 now includes a full implementation of the S.A.M. text to speech code as discussed previously in this thread
The syntax of the new command is:
TTS "text" [,speed] [,pitch] [,mouth] [,throat] [,interruptroutine]
or
TTS PHONETIC "phonetic text" [,speed] [,pitch] [,mouth] [,throat] [,interruptroutine]
The use of the parameters is best explained by the referenced document above.
The optional parameters can be omitted e.g.
TTS "Mary had a little lamb"
TTS "its fleece was white as snow",,80,,100
TTS PHONETIC "DHAH4 MUW4",,,,,myint
defaults are:
speed = 72
pitch = 64
mouth = 128
throat = 128
The speech outputs on the MMX audio port in dual mono (both channels have the same output) so if you have a Backpack144 just plug into the jack socket and enjoy a blast from the past.
The command is non-blocking and optionally can call a termination interrupt.
This will be the last bit of functionality in MMX5.3 as I really must get on with some other projects. I will of course post bug fixes as and when they are necessary.
Enjoy!
Demo program
Option explicit
option default NONE
dim a$
dim integer i
open "crab.txt" for input as #1
do
i=0
line input #1, a$
print a$
if a$<>"" then
TTS a$,,,,,myint
do
loop until i=1
endif
loop until eof(#1)
close #1
end
sub myint
i=1
end sub
2017-03-04_194149_crab.zip Edited by matherp 2017-03-05
Posted: 10:07am 04 Mar 2017
I don't know why you say "not remotely useful". Surely this would be tremendously useful for warnings, annunciations, etc.
  matherp said  This will be the last bit of functionality in MMX5.3 as I really must get on with some other projects.
Everyone will have withdrawal symptoms!
plasma
Posted: 09:58pm 04 Mar 2017
haha its great , Frank will go crazy about this.
only for curiosity : what do you mean with "some other projects"?
Zonker
Posted: 02:41am 05 Mar 2017
Wow..! Eye balls and now a mouth..!
Lou will think this is awesome..! We can now create his ham radio repeater controller using only the MMX..! No click board necessary...
Very useful Peter..!!
Frank N. Furter
Posted: 05:11am 05 Mar 2017
@Plasma: You are right!
That' really great! AWESOME!!!
I use in the meantime the micro:bit which has also a S.A.M. implemented.
I have unfortunately no Micromite Extreme! Is there a way to implement S.A.M. as a c-function on a MM2????
Frank
Lou
Posted: 11:20am 05 Mar 2017
Good one, yes great for a repeater controller if the voice is easily understandable over the radio.
I hope someone puts up an MMX demo on YouTube.
Thanks Peter.
Posted: 12:32am 06 Mar 2017
Unfortunately the SAM speech is not quite up to the quality for radio and/or alarm warnings
This is why Peter has mentioned it is more for 'fun' - possibly you can create some useful sound effects rather than speech.
This is 'old technology' in terms of speech capability and all Peter has done is implement it (i.e. other peoples coding) on a MicroMite eXtreme. Hopefully it will bring back memories for some of you
WWEdited by WhiteWizzard 2017-03-07
f1fco
Posted: 12:37am 06 Mar 2017
hello to all,
do you know if exist an external speech synthesizer (hardware) who speak FRENCH ?
thank you for a link
Pierre, french hamradio F1FCO
73s de F1FCO
Posted: 12:47am 06 Mar 2017
Hi Pierre,
'Commercially available' units are out there at a price. Some Googling reveals quite a lot of results but you may need to filter out the companies that are still in business - and probably contact them by email.
For example: TextSpeak
WW
astro1
Posted: 01:03am 27 Mar 2017
Anyone try playing a wav file then a TTS command.
play wav "file.wav"
TTS "Hello There"
TTS speed has increased a bit. Running with the defaults is unchanged, reset button works.
