Local Time 20:22 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - atmosphere properties
cdeagle
Posted: 10:02am 03 Mar 2017
This post describes a program for the Micromite eXtreme that can be used to determine the metric properties of the U.S standard atmosphere. It is valid between the altitudes of zero and 1000 kilometers.
Here's a typical screen display generated by the software.
properties of the U.S. 1976 standard atmosphere
altitude (kilometers) = 100
temperature (degrees Kelvin) = 195.081
density (kilograms/cubic meter) = 5.60401e-07
pressure (newton/square meter) = 0.032011
speed of sound (meters/second) = 274.039
Here's the source code for a demo program and the subroutine. Be sure to always read the atmospheric data arrays before calling the us76.bas subroutine.
' demo_us76.bas
' this program demonstrates how to interact with the
' us76.bas subroutine which computes the properties
' of the U.S. 1976 standard atmosphere between zero
' and 1000 kilometers altitude
' dimension atmospheric data arrays
dim zs(49) as float, ps(49) as float, tms(49) as float, wms(49) as float
' read atmospheric data
for i% = 1 to 49
read zs(i%)
next i%
data 0.0, 11.019, 20.063, 32.162, 47.35, 51.413
data 71.802, 86.0, 91.0, 94.0, 97.0, 100.0, 103.0
data 106.0, 108.0, 110.0, 112.0, 115.0, 120.0, 125.0
data 130.0, 135.0, 140.0, 145.0, 150.0, 155.0, 160.0
data 165.0, 170.0, 180.0, 190.0, 210.0, 230.0, 265.0
data 300.0, 350.0, 400.0, 450.0, 500.0, 550.0, 600.0
data 650.0, 700.0, 750.0, 800.0, 850.0, 900.0, 950.0, 1000.0
for i% = 1 to 49
read tms(i%)
next i%
data 288.15, 216.65, 216.65, 228.65, 270.65
data 270.65, 214.65, 186.95, 186.87, 187.74
data 190.40, 195.08, 202.23, 212.89, 223.29
data 240.00, 264.00, 300.00, 360.00, 417.23
data 469.27, 516.59, 559.63, 598.78, 634.39
data 666.80, 696.29, 723.13, 747.57, 790.07
data 825.31, 878.84, 915.78, 955.20, 976.01
data 990.06, 995.83, 998.22, 999.24, 999.67
data 999.85, 999.93, 999.97, 999.99, 999.99
data 1000.00, 1000.00, 1000.00, 1000.00
for i% = 1 to 49
read wms(i%)
next i%
data 28.9644, 28.9644, 28.9644, 28.9644, 28.9644
data 28.9644, 28.9644, 28.9522, 28.889, 28.783
data 28.620, 28.395, 28.104, 27.765, 27.521
data 27.268, 27.020, 26.680, 26.205, 25.803
data 25.436, 25.087, 24.749, 24.422, 24.103
data 23.792, 23.488, 23.192, 22.902, 22.342
data 21.809, 20.825, 19.952, 18.688, 17.726
data 16.735, 15.984, 15.247, 14.330, 13.092
data 11.505, 9.718, 7.998, 6.579, 5.543
data 4.849, 4.404, 4.122, 3.940
for i% = 1 to 49
read ps(i%)
next i%
data 1013.25, 226.32, 54.7487, 8.68014, 1.10905
data 0.66938, 0.039564, 3.7338e-3, 1.5381e-3
data 9.0560e-4, 5.3571e-4, 3.2011e-4, 1.9742e-4
data 1.2454e-4, 9.3188e-5, 7.1042e-5, 5.5547e-5
data 4.0096e-5, 2.5382e-5, 1.7354e-5, 1.25054e-5
data 9.3568e-6, 7.2028e-6, 5.6691e-6, 4.5422e-6
data 3.6930e-6, 3.0395e-6, 2.5278e-6, 2.1210e-6
data 1.5271e-6, 1.1266e-6, 6.4756e-7, 3.9276e-7
data 1.7874e-7, 8.7704e-8, 3.4498e-8, 1.4518e-8
data 6.4468e-9, 3.0236e-9, 1.5137e-9, 8.2130e-10
data 4.8865e-10, 3.1908e-10, 2.2599e-10, 1.7036e-10
data 1.3415e-10, 1.0873e-10, 8.9816e-11, 7.5138e-11
' define altitude and compute properties
alt = 100.0
us76(alt, atmtmp, atmdns, atmprs, atmsos)
' display results
print " "
print "properties of the U.S. 1976 standard atmosphere"
print "-----------------------------------------------"
print " "
print "altitude (kilometers) = ", alt
print " "
print "temperature (degrees Kelvin) = ", atmtmp
print " "
print "density (kilograms/cubic meter) = ", atmdns
print " "
print "pressure (newton/square meter) = ", atmprs
print " "
print "speed of sound (meters/second) = ", atmsos
print " "
end
sub us76(alt, atmtmp, atmdns, atmprs, atmsos)
' U.S. 1976 standard atmosphere subroutine
' input
' alt = altitude (kilometers)
' output
' atmtmp = temperature (degrees Kelvin)
' atmdns = density (kilograms/cubic meter)
' atmprs = pressure (newton/square meter)
' atmsos = speed of sound (meters/second)
local i%, j%
z = alt
' altitude must be less than 1000 kilometers
if (z > 1000.0) then
z = 999.0
end if
' determine positive altitude values
if (z >= 0.0) then
' set initial values
ro = 6356.766
go = 9.80665
wmo = 28.9644
rs = 8314.32
zm = z * 1000.0
rom = ro * 1000.0
' altitudes greater than 86 kilometers
if (z >= 86.0) then
' find pointer location
for i% = 8 to 48
if (zs(i%) <= z and z < zs(i% + 1)) then
exit for
end if
next i%
' calculate temperature
if (i% = 8) then
t = tms(9)
elseif (not (i% < 16 or i% >= 19)) then
t = 240.0 + 12.0 * (z - 110.0)
elseif (i% >= 19) then
xi = (z - 120.0) * (ro + 120.0) / (ro + z)
t = 1000.0 - 640.0 * exp(-0.01875 * xi)
else
t = 263.1905 - 76.3232 * sqr(1.0 - ((z - 91.0) / 19.9429)^2)
end if
' set pointers
j% = i%
if (i% = 48) then
j% = i% - 1
end if
' calculate altitude indices values for molecular weight calculation
z0 = zs(j%)
z1 = zs(j% + 1)
z2 = zs(j% + 2)
' calculate molecular weight
wma = wms(j%) * (z - z1) * (z - z2) / ((z0 - z1) * (z0 - z2))
wma = wma + wms(j% + 1) * (z - z0) * (z - z2) / ((z1 - z0) * (z1 - z2))
wma = wma + wms(j% + 2) * (z - z0) * (z - z1) / ((z2 - z0) * (z2 - z1))
' calculate atmospheric pressure indices
alp0 = log(ps(j%))
alp1 = log(ps(j% + 1))
alp2 = log(ps(j% + 2))
' calculate pressure
alpa = alp0 * (z - z1) * (z - z2) / ((z0 - z1) * (z0 - z2))
alpa = alpa + alp1 * (z - z0) * (z - z2) / ((z1 - z0) * (z1 - z2))
alpa = alpa + alp2 * (z - z0) * (z - z1) / ((z2 - z0) * (z2 - z1))
' set second side of molecular weight and pressure value
alpb = alpa
wmb = wma
' perform same calculations for far side values for smoothing
if (not (i% = 8 or i% = 48)) then
j% = j% - 1
z0 = zs(j%)
z1 = zs(j% + 1)
z2 = zs(j% + 2)
' calculate pressure indices values for pressure calculation
alp0 = log(ps(j%))
alpb = alp0 * (z - z1) * (z - z2) / ((z0 - z1) * (z0 - z2))
alpb = alpb + alp1 * (z - z0) * (z - z2) / ((z1 - z0) * (z1 - z2))
alpb = alpb + alp2 * (z - z0) * (z - z1) / ((z2 - z0) * (z2 - z1))
wmb = wms(j%) * (z - z1) * (z - z2) / ((z0 - z1) * (z0 - z2))
wmb = wmb + wms(j% + 1) * (z - z0) * (z - z2) / ((z1 - z0) * (z1 - z2))
wmb = wmb + wms(j% + 2) * (z - z0) * (z - z1) / ((z2 - z0) * (z2 - z1))
end if
' calculate pressure and molecular weight from derived constants
p = 100.0 * exp((alpa + alpb) / 2.0)
wm = (wma + wmb) / 2.0
else
for i% = 1 to 7
exit for
end if
next i%
' calculate altitude breakpoints
zl = ro * zs(i%) / (ro + zs(i%))
zu = ro * zs(i% + 1) / (ro + zs(i% + 1))
' convert to meters
zlm = zl * 1000.0
zum = zu * 1000.0
wm = wmo
ht = (ro * z) / (ro + z)
hm = ht * 1000.0
g = (tms(i% + 1) - tms(i%)) / (zu - zl)
gm = g * 0.001
' calculate pressure and temperature
if (g < 0.0 or g > 0.0) then
p = ps(i%) * ((tms(i%) / (tms(i%) + g * (ht - zl)))^((go * wmo) / (rs * gm))) * 100.0
else
p = ps(i%) * exp(-(go * wmo * (hm - zlm)) / (rs * tms(i%))) * 100.0
end if
t = tms(i%) + g * (ht - zl)
end if
' calculate density
d = (wm * p) / (rs * t)
else
' set default values for negative altitudes
t = 288.15
p = 101325.0
d = 1.224999155888
end if
' calculate speed of sound
if (z < 91.0) then
ss = 20.046707 * sqr(t)
else
ss = 274.0392912
end if
atmdns = d
atmtmp = t
atmsos = ss
atmprs = p
end sub
