Local Time 16:29 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Flow Simulation
paceman
Posted: 02:56am 18 Jan 2017
In the V5.3 "Reguests" thread here LouisG requested a flow simulation command. Some members suggested doing it in MMBasic was a good idea so I've improved the MMBasic V5.2 code I hashed up then and it now allows horizontal or vertical and forward or reverse code. This is running on an MX170 MM2 with an ILI9341 screen but should work with all other later variants because it uses just the basic graphics commands.
The code below is a demo to show how the subroutine works but it needs a technique to get rid of the PAUSE command that holds up the main program flow.
Can someone show how to do this but still be able to get back to the calling program with the simulation running since to use the subroutine, 'pipes' will variously need to be shut off/reversed etc while others keep 'running'.
It also needs a few symbols for valves, pumps etc which could be bitmaps or a special font set made using TassieJim's Font-Tweak utility. If it's useful that can be done later.
Greg
'FLUID FLOW SIMULATION - MMBasic V5.2 using the MX170 Micromite & ILI9341 LCD Display
' Greg Yaxley (paceman on TBS)
cls
const white = rgb(white)
const red = rgb(red)
const blue = rgb(blue)
const Green = RGB(green)
const gray = RGB(gray)
const yellow = rgb(yellow)
dim integer stx,sty,finx,finy,diam
dim integer speed,direction
Main:
cls
BOX 70, 10, 60, 30, 2,white,blue
TEXT 72, 12, "HEADER",,,,yellow,blue
BOX 240, 80, 40, 50, 2,white,red
CIRCLE 260, 200, 20, 2,,white,yellow
speed = 20
do
flow(10,24,260,24,5,white,blue,speed,1)
flow(260,24,260,80,5,white,blue,speed,1)
flow(260,130,260,200,5,white,red,speed,1)
flow(100,200,260,200,5,white,red,speed,-1)
flow(100,105,100,200,5,white,red,speed,-1)
flow(10,105,240,105,8,blue,red,speed,-1)
loop
sub flow(stx,sty,finx,finy,diam,cull1%,cull2%,speed,direction)
'Fluid flow is indicated as alternate coloured segments - forward, reverse or stationary.
'Forward flow (direction) is the default and defined as left to right and top to bottom of screen.
'Reverse flow (direction = -1) is right to left or bottom to top of screen.
'Pipe start/finish positions must be entered left to right or top to bottom of screen.
'Flow simulation derives from the part-segment "offset" alternately displayed at the start of
'the "pipe" and the "speed" pause between segment movements.
'The segment length variable can be varied, or fixed in the code.
local integer tempx, tempy, segment=10, offset, count
local integer endfirstseg, stsecseg, endsecseg
if stx-finx and sty-finy <> 0 then print "Pipe must be vertical or horizontal": end
if stx>finx or sty>finy then print "Pipes must be defined left to right or top to bottom": end
offset = segment\2 'flow simulation is best when "offset" is about half the segment length
if stx = finx then goto Vertical 'test for vertical pipe
Horizontal:
tempx = stx
do
'Calc start & finish positions of two alternate coloured segments. Test for end of pipe before
'displaying each segment. Re-calculate positions after incrementing the start by two segments.
do
endfirstseg = stx + segment: stsecseg = endfirstseg+1: endsecseg = stsecseg + segment
if endfirstseg >= finx then LINE stx, sty, finx, finy, diam, cull1%: exit do
LINE stx, sty, endfirstseg, finy, diam, cull1%
if endsecseg >= finx then LINE stsecseg, sty, finx, finy, diam, cull2%: exit do
LINE stsecseg, sty, endsecseg, finy, diam, cull2%
stx = endsecseg + 1 'increment next segment-pair start position.
loop
if count = 3 then exit sub 'we're back to start condition
if speed = 0 then exit sub 'because flow is stopped, i.e. = 0
stx = tempx 'reset pipe start position
count = count+1 'flag to control whether the "offset" part-segment is needed next
Pause speed 'for the flow simulation
if direction = -1 then swap(cull1%,cull2%) 'for reverse flow to maintain correct simulation
if count < 2 or count = 3 then 'has pipe been re-filled after offset or from start?
line stx, sty, stx + offset, finy, diam, cull2% 'display the 'offset' segment in next colour
stx = stx + offset 'offset the start of 'normal' segment posns & re-fill (back to DO)
else
swap(cull1%,cull2%) 'no offset segment req'd, so change colour then re-fill pipe
endif
loop
exit sub
Vertical:
tempy = sty
do
do
endfirstseg = sty + segment: stsecseg = endfirstseg+1: endsecseg = stsecseg + segment
if endfirstseg >= finy then LINE stx, sty, finx, finy, diam, cull1%: exit do
line stx, sty, stx, endfirstseg, diam, cull1%
if endsecseg >= finy then LINE stx, stsecseg, finx, finy, diam, cull2%: exit do
LINE stx, stsecseg, finx, endsecseg, diam, cull2%
sty = endsecseg + 1 'increment next segment-pair start position
loop
sty = tempy 'reset pipe start position
line stx, sty, finx, sty + offset, diam, cull2% 'display the "offset" segment in next colour
sty = sty + offset 'offset start of seg "normal" segment posns & re-fill (back to DO)
else
endif
loop
end sub
SUB Swap a%, b%
LOCAL t%
t% = a%: a% = b%: b% = t%
END SUB
disco4now
Posted: 09:32pm 18 Jan 2017
Hi Greg,
I have had a play with this and have a SETTIMER updating in the background.
Touching the screen will reverse the flows as a simple demo of the touch interface.
The flow displays looks good, and with a few graphics using Jim's program I can see it could be quite a nice interface.
Well done.
Gerry
'Modified to use SETTIMER to update the flows in the background. G.A.
'Touching the sreen will reverse the flows.
cls
dim integer speed,direction,speedcounter
'Setup arrays to hold data for the pipes
DIM INTEGER phase(10) 'The current write phase of each pipe display
Dim Integer pipespeed(10)= (0,0,0,0,0,0,0,0,0,0,0) ' speed divider for pipes. 0 is stopped, 1 is fastest. 9 is slowest
DIM INTEGER flowdirection(10)=(0,0,0,0,0,0,0,0,0,0,0) ' direction of flow. -1 is reverse anything else is forward or down
Main:
cls
' Start the settick timer to run as our update thread
SETTICK 10,BackGroundThread,4
T_IRQ=peek(byte peek(word &H9D000090) + 23) 'read the Touch Interupt
SetPin T_IRQ, INTL, TouchDown ' set interrupt to detect touch
'setup pipe initial direction and speed
flowdirection(3)=-1
flowdirection(4)=-1
flowdirection(5)=-1
pipespeed(0)=1
pipespeed(1)=2
pipespeed(2)=1
pipespeed(3)=4
pipespeed(4)=1
pipespeed(5)=5
do
END
SUB BackGroundThread
'disable the tick timer while its processing
SETTICK 0,0,4
speedcounter=speedcounter+1
' call each pipe and update if required
flow(0,10,24,260,24,5,white,blue)
flow(1,260,24,260,80,5,white,blue)
flow(2,260,130,260,200,5,white,red)
flow(3,100,200,260,200,10,white,red)
flow(4,100,105,100,200,5,white,red)
flow(5,10,105,240,105,8,blue,red)
're enable the tick timer
SETTICK 20,BackGroundThread,4
end sub
SUB TouchDown
'? touch(x)
for x =0 to 5
if flowdirection(x)=-1 then
flowdirection(x)=0
else
flowdirection(x)=-1
endif
next x
sub flow(pipeno,stx,sty,finx,finy,diam,cull1%,cull2%)
'get current count for this pipe
count=phase(pipeno)
speed=pipespeed(pipeno)
direction=flowdirection(pipeno)
if speed <> 0 then
if speedcounter\speed<>speedcounter/speed Then exit sub
else
count=0
end if
Horizontal:
tempx = stx
if count=1 or count=3 then
END IF
end IF
stx = stx + count*offset 'offset the start of 'normal' segment posns
' write the pipe segements
do
loop
' now fix up the first segement
stx = tempx
if count = 1 or count = 2 then
line stx, sty, stx + count*offset, finy, diam, cull2%
END IF
if count=3 then
line stx, sty, stx + offset, finy, diam, cull1%
line stx+offset, sty, stx + count*offset, finy, diam, cull2%
END IF
ELSE
end if
if count = 3 then
end if
end if
'setup for next write
count=count+1
if count=4 then count=0
phase(pipeno)=count
exit sub
Vertical:
tempy = sty
END IF
end IF
sty = sty + count*offset 'offset the start of 'normal' segment posns
do
loop
sty = tempy
line stx, sty, finx , sty+ count*offset, diam, cull2%
END IF
if count=3 then
line stx, sty, finx, sty + offset, diam, cull1%
line stx, sty+offset , finx, sty + count*offset, diam, cull2%
END IF
ELSE
line stx, sty, finx, sty + count*offset, diam, cull2%
end if
if count = 3 then
line stx, sty+offset, finx, sty + count*offset, diam, cull2%
end if
end if
count=count+1
phase(pipeno)=count
end sub
sub flowORG(stx,sty,finx,finy,diam,cull1%,cull2%,speed,direction)
Horizontal:
tempx = stx
do
do
loop
else
endif
loop
exit sub
Vertical:
tempy = sty
do
do
loop
else
endif
loop
end sub
SUB Swap a%, b%
LOCAL t%
END SUB
F4 H7FotSF4xGT
paceman
Posted: 01:17am 19 Jan 2017
Thanks for taking the time with this Gerry, yours is a lot better, it's nicely smoother and fixes the PAUSE problem. I knew that a SETTICK was going to have to be involved but couldn't figure how to incorporate it - and a "background" subroutine was something that didn't even occur to me. I think I was hung up on a "simple" solution and that obviously wasn't going to happen! Now I just need a day or two to really check out what your code's doing - my programming skills are pretty limited and very rusty.
The "touch" reverse is a nifty demo (love your "read touch interrupt" line ) . It would work well with say a valve or a pump graphic but would need to be specific to a given pipe. A quick look says your code can probably do that - I need to study it.
As you say, I think this simulation could be useful, especially if people need to, or want to stick with the smaller (DIP) processor. Geoff hasn't put a flow simulation as a "control" yet on the Micromite+ firmware so the more advanced Micromites could benefit too.
I've played with Jim's FontTweak but have yet to get round to actually displaying a "graphic" I've created. I'll have to remedy that, maybe some valves in different orientations and similar for pump symbols - I should look up some standard Chem Eng symbols for ideas.
Thanks again for looking at it - I nearly drove myself nuts trying to get it to work!
Greg
