Local Time 15:47 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick file question....
Posted: 05:58pm 24 Dec 2016
Hi all.
"Merry Christmas and all that bollocks."
- Bottom (TV series)
Are you not allowed to specify the path in filename strings?
Example:
If I change the directory FIRST, then it works fine, but I thought you could specify the path in the string?
Looks like I might be perhaps thinking of something else, but I was sure you could do it like this.......
BobD
Posted: 08:00pm 24 Dec 2016
Merry Christmas Grogs
I found the info below in the Addendum.
OPEN fname$ FOR mode AS [#]fnbr
Opens a file for reading or writing.
‘fname’ is the filename (8 chars max) with an optional extension (3 chars max)
separated by a dot (.). The default directory must be selected first using CHDIR (ie, a path is not accepted).
‘mode’ is INPUT, OUTPUT, APPEND or RANDOM.
INPUT will open the file for reading and throw an error if the file does not
exist. OUTPUT will open the file for writing and will automatically overwrite
Posted: 09:09pm 24 Dec 2016
NICE FIND!!!!
I'm not sure how I missed that in the manual.....
BobD
Posted: 09:46pm 24 Dec 2016
  Grogster said   NICE FIND!!!!
It wasn't easy to find. I wonder why it's in the Addendum.
Posted: 10:06pm 24 Dec 2016
Probably cos this only relates to the MM+, as the standard 170 MM2 does not have native SD card support.
Why am I writing code on Christmas Day anyway?! (rhetorical!)
