Local Time 14:40 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI page error...
Posted: 05:31pm 20 Dec 2016
Hi everyone.
GUI setup 1
Font 7,4
GUI caption #1, "MAIN MENU:", 85, 15, LT, RGB(magenta)
CLS
GUI Page 1
Do:Loop
Result is:
GUI Page 1
Error: Invalid command.
MMBASIC 5.2, on E100.
Any ideas?
Manual says this should work, unless I am missing something very obvious.....
EDIT: It would appear that you DON'T specify the "GUI" part of this command, you just use PAGE 1 - I found that by accident while re-reading page 30 of the advanced manual, where they use a different syntax in the example.
Do we have an error in the manual that needs fixing? Edited by Grogster 2016-12-22
Posted: 06:18pm 20 Dec 2016
Never used the GUI PAGE commands so a guess.
The system defaults to PAGE 1 so GUI PAGE 1 does nothing
TRY GUI PAGE 2 which should give you a blank page then GUI PAGE 1 to go back to the start page.
I expect that GUI PAGE 1 while on PAGE 1 should be OK but switching pages is worth a try.
Posted: 09:50pm 20 Dec 2016
Good find, thanks Grogs.
Yes, the PAGE command should not be prefixed with GUI. I will fix the manual in the next release.
Posted: 11:15pm 20 Dec 2016
I've been playing with the pages feature - having dropped the "GUI" from the front of it, and it certainly is a nice feature to have. I can call these directly from the command-prompt for the purposes of testing/debugging - pretty cool.
