Local Time 13:35 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC
lew247
Posted: 09:34pm 08 Dec 2016
When using an RTC such as a DS2321
How many times can you set the time/date?
Is there a maximum number of times?
I know once set it will keep accurate time without being set again for up to a year, I'm just wondering if it would be detrimental to it having the time set once a day from a gps unit
I know it doesn't NEED this - but ....
BobD
Posted: 10:21pm 08 Dec 2016
Lewis
There are no restrictions on how often you set or get the time from a DS3231.
Bob
lew247
Posted: 11:03pm 08 Dec 2016
Thanks Bob
redrok
Posted: 05:07am 09 Dec 2016
Hi Lew247;
Yes to what Bob said.
Virtually all the clocks use internal static CMOS memory
to store and update the time and other parameters. Static
memory doesn't have a "wear out" mechanism so you can
read and write to your hearts content.
redrok
