Local Time 14:36 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PEEK problem
panky
Posted: 05:24pm 30 Nov 2016
Geoff,
It appears that the function PEEK(VARADDR var()) creates a zero length array which can not be erased, reDIM'd or have any data entered into it - see code below:-
> new
> clear
> dim a$(5)
> a$(0)="A"
> a$(4)="B"
> erase a$
> dim a$(8)
> a$(0)="T"
> a$(7)="P"
> erase a$
> a$(0)="H"
Error: A not declared
> ' all as you would expect
> new
> clear
> a$(0)="K"
> ' as you would expect
> print hex$(peek(varaddr a$()))
A001DEF8
> a$(0)="Y"
Error: Index out of bounds
> erase a$
Error: Cannot find A
> dim a$(4)
Unsure if this classifies as a bug or just a limitation to take note of. For your info.
Doug.
Posted: 06:21pm 30 Nov 2016
Nice find.
Looks like it might be a bug.
Posted: 09:07pm 30 Nov 2016
Good one, thanks.
