Local Time 13:35 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial HEX Receive to ASCII
2001cpx
Posted: 02:06pm 28 Nov 2016
HI!
(Using Micromite,with Graph Il9341)
Tried to Convert Serial data (HEX) ((Non Printable) to ASCII witout Succes,
with Read,Search,Trial error,etc.
Here is What is Receive In Micromite: (also Sniffed)
(20 Bytes)
0x13,0x00,0x01,0x01,0x01,0x0C,0x33,0x0F,0x2C,0xD4,0xB7,0xB0,0x67,0x09,0x97,0xE3,0x2B,0x2B,0x40,0xB4
(13000101010C330F2CD4B7B0670997E32B2B40B4)HEX
what i want is to Convert this data to ASCII,here Sloppy Code,only for test :
Option autorun on
SetTick 1000,DOINT
's$="0997D87388" 'String Chooped, test
't$="330F2CD4B7B0670997D87388" 'string complete
'u$="41202250634"'string decimal
'050001FBF23D reception
'13000101010C330F2CD4B7B0670997E32B2B40B4 string 20 bytes
'dim integer i=val("&h"+ e$)
c$=""
Open "com1:57600,42,SerialInt" As #1
Color RGB(255,255,255),RGB(120,120,120):CLS:Font 2
GUI caption #3, "1 abc 2", 0,0,,RGB(white),0
GUI caption #4, "3 def 4", 0,20,,RGB(green),0
GUI caption #5, "5 ghi 6", 0,40,,RGB(red),0
GUI displaybox #11,1,62,317,176,RGB(yellow),0
Text 18,190," ",,,,RGB(RED),0
Text 18,210," ",,,,RGB(green),0
Pause 500
Text 18,70, c$,,,,RGB(red),0
Print c$
Print ess
Print e$
SerialInt:
c$=""
Text 18,210,"(COM1==> RX )",,,,RGB(Green),0
C$= Input$(20,#1)
ess = Len(c$)
e$= Mid$(c$,7,8)
'e$ = Left$(c$,1)
'If e$ <> Chr$(&H33) Then flag3=1:IReturn
'If e$ <> "33" Then flag3=1:IReturn
'd$ = Right$( c$, 10 )
'i=Val("&H"+ d$)
'Print #2, Str$(i)
'flag2 = 1
IReturn
Sub DOINT
Text 18,190,"(COM1==> TX )",,,,RGB(RED),0
Print #1,Chr$(&h04);Chr$(&h00);Chr$(&h01);Chr$(&hDB);Chr$(&h4B);'send command to RFID Module
Thanks In Advance for your Help
"Color Maximite,(Duinomite-Mega,Mini),CGmmStick,GCmicroboard2b,Micromite + explore 64,100,LCD backpack,Lcd Backpack V2,TFT Backpack,Micromite Extreme,Armmite L,F,H,CMM2"
Posted: 10:24pm 28 Nov 2016
I assume the incoming data is in a string variable?
say s$
then to print the 5th character in hex use:
print hex$(asc(mid$(s$,5,1)),2)
Edited by matherp 2016-11-30
2001cpx
Posted: 09:39am 29 Nov 2016
Thanks For Your Help!
and Now,
how i can Print all Chars? and saving in Strings?
Thanks!
(before i used Proton Basic,which is Good,but i like More Micromite,and
i learn everyday!)
2001cpx
Posted: 03:23pm 29 Nov 2016
Now this Work,But not sure is a good way to do that,anyway,
i begin to know more about HEX to Ascii,dec etc
when you know another language,it s very difficult,anyway for me.
I love Micromite!!!
(more than 2 days to achieve this...)
Option autorun on
SetTick 1000,DOINT
option explicit
'13000101010C330F2CD4B7B0670997E32B2B40B4 string 20 bytes(i receive this <==)
Dim string Var1$,Var2$,var5$,S$
dim integer K=val("&h"+ var5$)
DIM RECBYTE$(20)
dim var3,var4(20),i,a,b,var6
Text 18,90,str$(var6),,,,RGB(RED),0
Pause 500
Text 18,110, var5$,,,,RGB(red),0
Print recbyte$(13),recbyte$(14),recbyte$(15),recbyte$(16),recbyte$(17)
var5$= recbyte$(13)+ recbyte$(14)+ recbyte$(15)+ recbyte$(16)+recbyte$(17)
K=Val("&H"+ var5$)
if k <10 then
var6 = 0
else
var6 = 1
endif
if var6 = 1 then
Text 18,130, str$(K),,,,RGB(white),0
else
Text 18,130, " ",,,,RGB(white),0
endif
SerialInt:
FOR A = 0 TO 19
S$ = INPUT$(1, #1)
RECBYTE$(A) = HEX$(ASC(S$),2)
NEXT A
IReturn
Sub DOINT
