Forum Index : Microcontroller and PC projects : ASCII Video Terminal for Micromite
| larny Guru Joined: 31/10/2011 Location: AustraliaPosts: 349 |
The July 2013 issue of Silicon Chip describes such a device. I have a Maximite & it seems to me that I could use it as a Micromite interface. It could be programmed to pass keyboard info to the MIcromite & receive info from the Micromite that the Maximite would display on a Monitor. I presume that it would be possible to pass info received from the USB onto the Micromite. Is this feasible? Has anyone done it? Len |
I did the VideoMite a while ago - that works well and I use it semi-frequently for testing quick things on the bench. VideoMite 1A Smoke makes things work. When the smoke gets out, it stops! |
Thanks Grogster. I'll file that for future reference. |
