Local Time 11:25 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Here is Micromite MZ (the other edition)
kiiid
Posted: 11:41pm 20 Nov 2016
Hi all, Geoff gave me the approval to announce this version. It is based on a completely rewritten PLIB and uses no Harmony at all. Includes double arithmetic, bootloader, multiple SD card support, 8-bit character support, a full 10x20 font #97 to allow 80x24 screen layout.
Attaching the file here for people to try. The zip file also includes the font as a separate file, so it can be included into existing applications.
Let me know if you spot any bugs.
Thanks!
2016-11-21_095803_MM.zip
Edited by kiiid 2016-11-22
http://rittle.org
Posted: 02:19am 21 Nov 2016
how does harmony compare to new-PLIB in terms of the quantity of flash consumed? and does the new-PLIB open the possibility of creating a non-microchip tool chain that can compile mmbasic?
also, is new-PLIB backwards compatible with the MX series processors? or is it MZ only? if new-PLIB produced smaller compiled code than old-PLIB, and was compatible with MX170 PICs, then it could provide a means to extend the functionality of the 28-pin micromite line.
rob :-)
Edited by robert.rozee 2016-11-22
kiiid
Posted: 04:58am 22 Nov 2016
In terms of flash consumed I don't know because I don't have Peter's source, which partly uses harmony. What is available now is much less than the actually available flash because there will be an internal drive A: occupying the rest of it in the near future. I think it is quite unlikely that someone will write a 400k program (that's about 50000 lines of MMbasic code) so what is available now should be sufficient for any purpose. Since the whole structure is optimised without overhead, the execution speed is slightly higher and the whole thing is more stable (well, IMO).
The new PLIB is backwards compatible with the MX version, so the same high-level code can (and will) be shared between the MZ and the MX versions.
http://rittle.org
sagt3k
Posted: 05:39am 22 Nov 2016
Hi kiiid
Your firmware will be free to use for personal and commercial scope?
sagt3k
kiiid
Posted: 05:44am 22 Nov 2016
  sagt3k said   Hi kiiid
sagt3k
Yes, the license is inherited from Geoff's source.
http://rittle.org
Posted: 06:06am 22 Nov 2016
  robert.rozee said   also, is new-PLIB backwards compatible with the MX series processors? or is it MZ only? if new-PLIB produced smaller compiled code than old-PLIB, and was compatible with MX170 PICs, then it could provide a means to extend the functionality of the 28-pin micromite line.
To guess:
I expect it's MZ only, since the MX one already exists, and is aimed to allow (almost) the same source to compile for MX or for MZ.
It won't create anything under MX as you'd be using the Mchp plib.
In any case, I don't recall plib as being really the cause of the MX170 being rather full.
kiiid please correct if I'm wrong :)
If you want to get more into the MX170 I expect it's doable but may be painful.
kiiid
Posted: 06:10am 22 Nov 2016
  JohnS said  I expect it's MZ only, since the MX one already exists, and is aimed to allow (almost) the same source to compile for MX or for MZ.
Correct! They are different libs using the same syntax functions. As to the 170, I have no interest in it and no idea whether it will be developed further by Geoff or someone else, as well.
http://rittle.org
sagt3k
Posted: 06:18am 22 Nov 2016
Concerning multiple drive ...
Is it possible to have spi/flash as c: ? Instead of uSD?
isochronic
Posted: 04:58pm 22 Nov 2016
  Quote  It is based on a completely rewritten PLIB and uses no Harmony at all.
Well done.
And I guess that could be used for moving other existing MX software to the MZ...
sounds distinctly profitable, ka-ching!
Edited by chronic 2016-11-24
