Local Time 10:35 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CS pin on LCD panel
Henk
Posted: 06:51am 07 Nov 2016
I am building a prototype circuit with the 28 pin micromite and and a 2.4 inch LCD panel with touch control. I am working with it for a few months now and the lcd panel and touch controller work fine without any problems. But now that I am at the point of documenting all connections for a defenitive design I noticed I have still connected the CS pin to ground. I did this because at the start I was not using the touch controls and the manual tells that you should connect it to GND in that case.
Now I am reading the manual again I noticed that if you use the LCDpanel AND the touch control you should give CS its own micromite PIN and configue it. I just forgot this when adding touch at a later stage and because all works well I had no reason to do so
Now my question, is it really necesarry to connect the CS pint to a micromite pin and configure it if you also use the touch facility? What could go wrong? I ask this because I used up all my micromite pins and an extra pin would be a problem. Maybe another type of LCDpanel will have problems with this?
Hope someone have an answer. Thanks.
