Local Time 07:48 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Security Bits - How to...
Zonker
Posted: 12:39pm 26 Sep 2016
I was wondering if there is a way to "lock-out" the MCU IC from being read back with the PICkit-3 (or any other shooter)...
Can you set a security bit in a Register with MPE..? I haven't read up on this yet... Just wondering if it could be done...
Thanks Gent's..!
Phil23
Posted: 02:04pm 26 Sep 2016
As in protecting a commercial product?
Think I've seen another thread discussing a unique serial number that could be read from the PIC. From memory one didn't exist.
How about this for a Band-Aid solution.
Add a single DS18B20 to the project & read it's serial number in the code for a security check.
Doesn't stop someone extracting the code as a Hex file, but I'm not sure how hard the Hex is to reverse engineer.
Phil.
Zonker
Posted: 02:32pm 26 Sep 2016
Hey Phil...
Yep, there are several good ways to do the same thing... But, I was wondering if there was a way to say "nope, can't read the flash" forever thing...
I'm not at the point of even wanting to, but, I know I have done this with other MCU's in the past... Just wondering... Will read up on it when I get the next "slice-O-time"... I know you should be able to... I was just wondering if anyone has done it before.. Edited by Zonker 2016-09-28
Posted: 10:09pm 26 Sep 2016
It can be protected such that you can only erase/write but not read until you've erased.
It's so that you can stop anyone copying your code (or disassembling it etc).
It's the CONFIG bit CP (code protect) I think - check the datasheet. You can set some of the CONFIG bits to do things like disable JTAG, too.
JohnEdited by JohnS 2016-09-28
