Forum Index : Microcontroller and PC projects : comms to mmedit
| jeffj Regular Member Joined: 04/02/2012 Location: AustraliaPosts: 84 |
I am experiencing a problem communicating to the computer from VT100 (250 IC)with MM edit. Teraterm works ok . I have swapped cables, ports and computer to no avail. Desktop is running XP and the laptop is WIN10 MMedit works ok on U mite 170 MM edit seems to recognise the same port as teraterm when I do a "find port" but comes up with an error saying that it can't find the port when I try to load programme Yr help would be appreciated jeff |
It is a known problem with the VT100 terminal (and some other similar devices) I don't have a fix so you will have to stick with TeraTerm until the VT100 firmware is updated. Sorry Jim VK7JH MMedit |
Ok thanks Jim Jeff |
redrok![]() Senior Member Joined: 15/09/2014 Location: United StatesPosts: 209 |
Hi jeffj; You may find that MMEDIT has taken control of the comm port. My solution is to disconnect MMEDIT's terminal program. Then connect Teraterm. Now Teraterm has control of the port. redrok |
That is interesting, Sorry Jim, I sent you a PM.. Chose to ignore it if you wish. It must have something to do with the `vt-100' formatting strings the Ascii terminal sends, I guess. ?? Kind Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
