Forum Index : Microcontroller and PC projects : FontTweak extra feature request
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
I guess this message mainly concerns TassyJim. Playing at the moment with FontTweak and trying to use it to create a custom font. It has very good functions, however I found impossible to change the size of the image matrix. For example if I load a font which is 16x16, I can't convert that to say 16x24 or 12x20 or something else. Basically that comes down to adding or trimming the needed number of lines/rows to or from the bit matrix. Would there be any possibility for this to be added? I believe there will be a very good use for it. Thanks! http://rittle.org -------------- |
It is something that is on the 'probably' list. I just need to get back to work on this and most other 'mite related software. Jim VK7JH MMedit |
Hi Jim, Been thinking about writing a Font Preview program to demonstrate various fonts on the different screens. Was think along these lines; [Code] Sub Whatever HWidth=MM.HRes\MM.FonWidth VRows=MM.VRes\MM.Font Height [/code] Then print a few sample strings & report the Text Res (Rows & Columns) at minimum spacing. But when I think a bit further I wonder if it would be easier for someone to do it in software. If the app could create a window appropriately sized, 320x240, 800x480 etc & just display a sample & report the resolution. Only other input it might be good for it to accept would be line spacing, either as Pixels or % of MM.FontHeight. Alternatively, is there anything already out there that does something similar. Phil. |
