Forum Index : Microcontroller and PC projects : MM+ Editor Bug?
Can others please check the following . . . . Setup is an E100 with TFT and PS2 running as a standalone system. Within the editor I am editing some code and using cursor keys to move the cursor around the code. IF I have an underscore character (i.e. as part of a variable name), then the cursor 80% of the time will remove the underscore character from the screen (but it is still there: exit editor, then re-enter, and underscores come back!) Happens in any of the four directions but not every time. Can others try this, AND also if anyone has a USB connection to something like TeraTerm see if it removes underscore character(s) from either/or the TT screen and TFT console screen Thanks, WW |
| dhester Newbie Joined: 17/07/2016 Location: United KingdomPosts: 11 |
WW I have tried this with both TeraTerm connected and without I get the same results. I.E the variable I use is t_demo and the underscore disappears on the tft but not on the serial connection. If no serial connection the underscore disappears. The underscore disappears all the time on my little demo. Does this help. |
WW Just tried again and if I cursor around the underscore disappears but when I get to the end of a line and hit return the underscore reappears. Hadn't noticed this before as I am fairly new to micromite. |
Thanks David - yes it helps to know it is nothing 'unique' to me. Geoff will pick up on this - just a 'cosmetic' bug so nothing major. |
Thanks Phil, I can guess what is causing this and I will fix it in the next release. Geoff Graham - http://geoffg.net |
