Local Time 05:26 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS3231 Interrupt Pulse
Justplayin
Posted: 11:25am 17 Aug 2016
Does anyone have some MMBasic code which will setup a DS3231 clock module to output a interrupt pulse once every second? I know someone posted similar code for a PCF8563 module a while back, but I would like to use a DS3231.
Thanks,
--Curtis
lew247
Posted: 09:28pm 17 Aug 2016
The SQW pin is a 1 Hz Square Wave output on some DS3231 modules
Justplayin
Posted: 09:58am 18 Aug 2016
  lew247 said   The SQW pin is a 1 Hz Square Wave output on some DS3231 modules
My modules have no output on SQW (yet), so I need to program them to provide one. Finally found TassyJim's code for the PCF8563 and tried it on a DS3231... As expected it didn't work.
--Curtis
mikeb
Posted: 10:45am 18 Aug 2016
The default squarewave frequency is 8192 Hz. You have to set 2 bits in the option register, in the RTC chip, to one of 4 options. Haven't got the datasheet on me at the moment but I thing that the output is disabled, by default, also.
There are 10 kinds of people in the world.
Those that understand binary and those that don't.
twofingers
Posted: 01:11pm 18 Aug 2016
@curtis
Maybe this is what you're looking for?
Dim crtl_reg%=0
RTC GETREG &H0E,crtl_reg%
Print Bin$(crtl_reg%)
'76543210
RTC SETREG &H0E,crtl_reg% And &B01100011 'clear bit 7,4,3,2
Bit 4,3 are for the frequency
0,0=1Hz
0,1=1.024kHz
1,0=4.096kHz
1,1=8.192kHz
Michael
EDIT
You will find the description of the control register (0Eh) at page 13 in Maxims datasheet for the DS3231.
In some cases it may be sufficient to set the control register (0Eh) to zero (for 1Hz SQW output).
RTC SETREG &H0E,0
Edited by twofingers 2016-08-19
Justplayin
Posted: 03:55pm 18 Aug 2016
Thanks Michael,
I think that may do it. There is output on the SQW pin now!
Been staring at the DS3231 data sheet all day. I could see what I wanted to change, but wasn't sure how to get to the register. Total forgot the RTC command provides access to the RTC registers.
A few more tests and I should be able to move forward again!
--CurtisEdited by Justplayin 2016-08-20
