Local Time 03:10 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A "weird" qustion
lew247
Posted: 05:34am 30 Jul 2016
SSD 1963 LCD's come with an SD card, and you can load pictures (bmp's) on the card to display on the LCD
Is it possible to use an 8 bit parallel EEPROM to store the pictures instead of the SD card? and load them from the EEPROM?
Something like this
Or is it a totally stupid idea?
I was thinking IF it was possible, then pictures "should" load faster than reading them from an SD card? (maybe)Edited by lew247 2016-07-31
Posted: 05:42am 30 Jul 2016
That device has far too many pins.
I've got some code that will load pictures from SD card 6x faster than currently the case. Need to do a bit more testing before posting.
Current times are:
Loading a 480 x 272 image on a 4.3" SSD1963
LOAD IMAGE "router.bmp" 5.1 seconds
DisplayPicture "router.ppm" 0.8 seconds
