Forum Index : Microcontroller and PC projects : Maximite Serial Baud Rate
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
I have just found that in BBCBasic ( even though the manual gives the standard baud rates ( as does the MMBasic manual )) I can write : port% = OPENUP("COM1: 31250,N,8,1") and instruct a Midi device. I had always thought deviating from the given rates would error some way. Will the Maximite do the same ? If so I could put the Midi device in the 'Sea of Holes' and have a slick unit :) |
The Duinomite can on com3 and com4 I think the Maximite is restricted to the standard rates. The micromites can use the SerialTx Cfunction which will do any baud rate up to a max limit. Jim VK7JH MMedit |
Thank You Jim, Yea, I remember the DuinoMite doing it now. It might be better, since I could change 'shields' (and synths) at whim. I had one once but trashed it when the SD card holder broke .............. |
