Local Time 02:25 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bargraph with LCD panel
lew247
Posted: 09:23pm 20 Jul 2016
Is it possible to have a bargraph - vertical or horizontal drawn on an LCd display in such a way that you can have a variable controlling the height or length that is filled in on the graph?
Similar to those shown on THIS Video on Youtube
I searched both manuals and couldn't find anything, and there is only a vague reference to it online in a post abut a Maximite which used the code [code]DrawHBar(x,y), val, colour, [BFS], val ranges from 0 to 100
DrawVBar(160,90),y/2.7,yellow,BFS
DrawHBar(210,160),x/4.8,green,BFS ' bargraph with box, fill, scale[/code]
However on searching the manual I cannot find a mention of the "DrawVBar" or DrawHBar" commands
centrex
Posted: 10:41pm 20 Jul 2016
Surely those two commands are sub routines within the main program that should show it was done.
Cliff
lew247
Posted: 11:27pm 20 Jul 2016
They don't seem to be
The program/post I saw is Here
I wonder if it's part of the code for Maximite that didn't go into the Micromite?
Edited by lew247 2016-07-22
Zonker
Posted: 12:05am 21 Jul 2016
Hey Lew...
Both rectangular and radial bar graphs can be done on the MM... Segments are just small drawn rectangles... Radial bar graphs are drawn with triangles.. Peter had some code that can get you started...
Phil23
Posted: 12:30am 21 Jul 2016
  centrex said   Surely those two commands are sub routines within the main program that should show it was done.
I'd take a stab at saying it's just a matter of drawing a box.
Pass the Percentage of scale to the Sub & draw it to the desired scale.
Bit like this.
[Code]
CLS
For N=1 To 100
H=MM.VRes*N/100
Y=MM.VRes-H1
Box 0,Y,40,H,,,RGB(red)
Pause 100
Next N
[/code]
Cheers.
lew247
Posted: 08:33am 22 Jul 2016
My micromite is broken at the moment so I can't try it till next week, but I'll give it a go as soon as I can
