Local Time 02:24 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Supply voltage for TSOP4838 (IR decoder)
Posted: 08:21am 20 Jul 2016
In the uMite manual (page 24) the supply voltage for the TSOP4838 is 5v.
Reading the datasheet of the part (http://www.vishay.com/docs/82459/tsop48.pdf it states it can be used between 2.5v and 5v.
Is there a reason why the manual has 5v as i would prefer to use 3.3v.
Reliability, sensitivity?
Reading more.. the sensitivity should not make any difference according a graph on page 4.
Anyone experience with using it with 3.3v?
Lou
Posted: 08:30am 20 Jul 2016
Jean,
I ran the parts on 10 units at 3.3 volts and they worked fine.
Lou
Posted: 08:42am 20 Jul 2016
Thanks Lou! I will do so as well.
