Local Time 01:26 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : No command prompt on Micromite!
thirsty
Posted: 03:43pm 08 Jul 2016
Hi Guys
I've bought the LCD backpack kit from SC and have constructed it and it all works fine with the clock software programmed in from SC.
I'm now trying to connect to it using a CP2102 USB to Serial interface again from SC and I've got it to connect using Tera Term and have the banner on the screen but that's as far as it gets - I don't have the ">" symbol so can't do anything.
I believe the setup is correct with the Rx and Tx pins as I'm seeing the banner in the emulator.
Any ideas?
I have ordered a Pickit 3 so I can reflash at some stage just don't have it yet.
mikeb
Posted: 04:11pm 08 Jul 2016
Hi Thirsty,
As it is programmed with the clock it is 'auto running' that program.
Press ctrl + C and the command prompt should appear.
MMedit, if you ever use it, does that for you.
Note that it will 'stop running' the program.Edited by mikeb 2016-07-10
There are 10 kinds of people in the world.
Those that understand binary and those that don't.
thirsty
Posted: 04:41pm 08 Jul 2016
Great thanks Mike. Works now :)
I was trying MMEdit but I was having the same problem. I just now clicked the "send ^C" button and that worked too
Thanks again for the quick response
mikeb
Posted: 05:34pm 08 Jul 2016
No prob's. It's the little things that catch us out most.
Don't be afraid to ask. We do.
