Local Time 01:26 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Comms Master/Multiple Slaves
Phil23
Posted: 12:23pm 06 Jul 2016
I know Master controllers to multiple slaves has been discussed a fair bit recently.
The concept of a HC-12 wireless serial UART on the master talking to multiple slaves HC-12 can be done, just needs requests & hand shaking etc.
[Code]
Master: "Hello Slave1, Send Me some data".
Slave1: "Slave1 Reporting, here's that data...".
Master: "Hello Slave2, Do this job..."
Slave2: "Slave2 Reporting, Job done successfully".
[/code]
Etc, etc.
All good as long as the logic makes sure they don't talk over each other.
But, can this be done with hard wired Com ports?
I know that generally RS-232 serial type coms can't be physically wired together.
Known that since forever... Level shifting just would not happen.
But is there a device that allows Master / Multiple Slave multiplexing that's simple to implement?
A simple chip solution?
One that would replicate the multi wireless environment.
Phil.
CircuitGizmos
Posted: 12:41pm 06 Jul 2016
RS-485 can do multidrop.
MMBasic supports RS-485. Look in the serial section. There is a drive enable PIN to define that works with RS-485 driver chips.
Justplayin
Posted: 01:28pm 06 Jul 2016
It might not suit your exact needs, but there is the option of software serial ports using CFunctions which are included in then firmware download. The PDF docs says the CFunctions work on any I/O pin to provide any number serial ports.
--Curtis
mikeb
Posted: 02:46pm 06 Jul 2016
Hi Phil,
Use an RS485 transceiver which will give you a simple 2 wire, differential, half duplex communications link capable of up to 4000 feet. Use COM1 and the DE enable pin described in the MM manual. Most 8 pin transceiver's have the same footprint so tie pins 2 and 3 together and wire to the MM DE enable pin. It will be completely transparent to your link so just use standard serial communications code. The first byte in your packet should be the address of the remote slave module so this device should be the only one that responds to a data request.
RS485 comms, using the Modbus Protocol, has been a specialty of mine for many years.
2016-07-07_004453_MAX3483.pdf
There are 10 kinds of people in the world.
Those that understand binary and those that don't.
mikeb
Posted: 02:54pm 06 Jul 2016
@Phil
PM me with a postal address and I can send you some surplus devices I have in stock 'gratus'.Edited by mikeb 2016-07-08
Phil23
Posted: 11:32pm 06 Jul 2016
  mikeb said   @Phil
Thanks Mike,
I'll take you up on that.
I can only make the monster bigger.....
Phil.
mikeb
Posted: 10:24am 07 Jul 2016
@Phil
It's fun watching monsters evolve sometimes.
I'll pull out what devices I have and await a postal address.
Mike B.
