Local Time 01:27 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : NotePad++ Language file.
Phil23
Posted: 12:39am 05 Jul 2016
Had a little play about with defining a language in NotePad++ a little while ago.
A bit of the colour code is working, numbers are working in certain instances.
Subs, Functions & Do loops can be collaped.
Can't figure how to handle IF statements yet though.
To use it, go to Language - Define your Language & import the XML file.
I don't want a replacement for MMedit, just somewhere to have other files open.
Nice thing is NP++ will recognise when an open file has changed & ask if you want to reload it.
Also attached some old code where you can see what works & what doesn't.
Phil.
2016-07-05_103742_MMbasic_Language__File.zip
2016-07-05_103854_Ceiling_Heat_Controller.zip
kiiid
Posted: 12:58am 05 Jul 2016
Aaah... I've been hoping for this to happen in a while. NP++ is my main editor. Thanks a lot!
http://rittle.org
Phil23
Posted: 01:28am 05 Jul 2016
Have a look under define your language at the "Folder & Defaults" tab.
That's where I put "DO", "SUB" & "FUNCTION".
Can't figure out how to setup IF though.
Phil.
