Local Time 00:26 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multiple DS18B20 on single pin
jtelectron
Posted: 03:27pm 28 Jun 2016
Hi everyone,
Can somebody explain what seems to me a problem:-
Connection of Multiple DSB1820 on a single pin.
I have an unusual need to connect 15 of these devices on 1 bus
in 3 wire mode.
Realising the need to reduce the 4.8k pullup resistor in value.
Most people seem to indicate that there are problems in coding
and implementing this method[The MicroMite provides for 1 pin/device]
Phil23
Posted: 05:51pm 28 Jun 2016
  jtelectron said
Hi everyone,
in 3 wire mode.
Hi JTE,
You might like to look thru some of my posts.
This thread is one of the more recent updates.
I've wanted all my temp sensors for a couple of projects on a single bus & pin and am doing just that successfully.
You should be able to find the code I've posted.
I use one piece of code to extract the serial numbers from individual devices.
(At this stage I need to connect them ONE AT A TIME, & copy the numbers down).
Then my main application just uses those serial numbers to address the sensors.
One project currently has 4 on a daisy chain bus, the other has them all star connected at a central point.
Both are still using a 4.7k pull-up.
Chers
Phil
jtelectron
Posted: 01:50pm 29 Jun 2016
Thanks Phil,
I will do my best to understand your
code and thanks all for your help!!
