Local Time 02:23 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite 5.2 Firmware Update
Posted: 11:09pm 23 Jun 2016
I have updated the Micromite firmware to Ver 5.2 and it can be downloaded from: http://geoffg.net/micromite.html
This is mostly a bug fix release with three main new features:
- Ability to trap errors.
- MsgBox() function for the MM+.
- The PAGE command for the MM+.
Check the Change Log for the details (it runs to one and a half pages). For anyone who has installed the previous beta version this release is almost the same with a couple of extra bug fixes.
Thanks again to everyone who has tried out the beta versions. Of all the bugs fixed only a couple were discovered by me, the rest were found by you and I am very grateful
Posted: 05:08am 24 Jun 2016
i'm afraid the 5.2 release version still contains the editor bug outlined here:
http://www.thebackshed.com/forum/forum_posts.asp?TID=8701&PN=4
(Posted: 03 June 2016 at 12:37am)
that places the cursor on the end of the status line at the bottom of the screen under certain conditions.
apologies,
rob :-)
kiiid
Posted: 05:33am 24 Jun 2016
Edit:
Has the GUI DEFAULT command disappeared?
Edited by kiiid 2016-06-25
http://rittle.org
lew247
Posted: 05:41am 24 Jun 2016
Tried downloading it and it says [quote]Whoops... cannot find that page
Page Not Found HTTP 404 - File not found[/quote]
Posted: 05:51am 24 Jun 2016
  Quote  Has the GUI DEFAULT command disappeared?
From the change log:
  Quote  The GUI DEFAULT command has been removed as its functionality is now
provided by the GUI SETUP command.
Posted: 06:56am 24 Jun 2016
Sorry Rob, I forgot to add in the notes that yours is the one bug that I have not been able to fix yet. It is a curly one.
Lewis, the link does work. Have you tried clearing your browser's cache?
lew247
Posted: 07:17am 24 Jun 2016
it's ok Geoff,. It came back online 10 minutes after I posted that
Maybe too many people were trying to download all at once
I tried to edit my post to say it's back but it wouldn't let me edit it
Phil23
Posted: 04:28pm 24 Jun 2016
Just noticed page 16 of the MM+ addendum manual...
[Code]
100-Pin Example
The Explore 100 board using the 100-pin Micromite Plus uses the following pin allocations:
Pin 48 is the SSD1966 LED_A control
Pin 1 is the touch Chip Select
Pin 40 is the touch IRQ input
Pin 39 is the touch click output (see the next chapter)
Pin 47 is the SD card Chip Select
The corresponding configuration commands are:
OPTION LCDPANEL SSD1963_5, LANDSCAPE, 48
OPTION TOUCH 1, 40, 39
OPTION SDCARD 47
64-Pin Example
For the Explore 64 board (64-pin Micromite Plus) the following allocations are recommended:.....[/code]
I'm sure all new users will appreciate that.
So good to have something that supported by thorough AND current documentation.
Phil
Posted: 05:23pm 24 Jun 2016
Page 63 of the standard manual, under OPTION ERROR, at the bottom of the description box it says:
  MicroMite Manual, Page 63 said  ON ERROR ABORT can make it very difficult to debug a program, so it is strongly recommended that only ON ERROR SKIP be used.
Is that actually worded correctly? Is it meant to be "ON ERROR IGNORE can make it very difficult to debug a program".........
I would have thought that normal abort and show the error message is what you WANT for debugging purposes.
Once you are totally sure the program is bug-free(a bold statement!), then you could have the ON ERROR IGNORE.
Am I correct in assuming that with ON ERROR IGNORE, the variables holding the error number and text are updated with the latest error? This would mean if you have a couple of errors, the variables would hold the number and text of the LAST error, but not necessarily the error that caused problems, which may have been an ignored error or two back.
Correct?
Posted: 01:04am 25 Jun 2016
Thanks Grogs, you are right.
  Quote  Am I correct in assuming that with ON ERROR IGNORE, the variables holding the error number and text are updated with the latest error? This would mean if you have a couple of errors, the variables would hold the number and text of the LAST error, but not necessarily the error that caused problems, which may have been an ignored error or two back.
Correct again.
disco4now
Posted: 02:13am 25 Jun 2016
Just a small thing I noticed when comparing the new Cfunctions.h to see what was new.
In the new CFunctions.h file the definition below at around line 74 is missing the closing bracket in the definition. i.e
#define putConsole(a ((void (*)(char)) Vector_putConsole) (a)
in place of
#define putConsole(a) ((void (*)(char)) Vector_putConsole) (a)
Gerry
F4 H7FotSF4xGT
kiiid
Posted: 10:50pm 26 Jun 2016
There is something wrong with the I2C support. A program which is working fine on 5.1 hangs to the level to require reset (!!!) on 5.2.
I was able to isolate the problem and it is coming from this line: I2C write TSLaddr, 1, 1, &Hb4
http://rittle.org
Posted: 02:17am 27 Jun 2016
Not good. I will have a look at it.
Posted: 03:18am 29 Jun 2016
  kiiid said   There is something wrong with the I2C support. A program which is working fine on 5.1 hangs to the level to require reset (!!!) on 5.2. I was able to isolate the problem and it is coming from this line: I2C write TSLaddr, 1, 1, &Hb4
I have not been able to get this to fail.
I presume that you are using the MM+ ?
Could it be because you are using option 1 (ie, a stop condition is not sent) ?
I have done a compare on the 5.1 source compared to 5.2 and the only differences are in the RTC commands, nothing has changed in the general I2C commands. Are you using RTC GETTIME by any chance?
Posted: 03:32am 29 Jun 2016
  Quote  Are you using RTC GETTIME by any chance?
A RTC GETTIME command in an interrupt routine could likely create problems for any option 1 command I2C and visa versa. The solution would be to set a flag after the option 1 command and check for it in the interrupt routine
kiiid
Posted: 06:09am 29 Jun 2016
It looks like the problem was related with the "brain loss" issue (I was outputing information on the LCD), so once it was gone, I didn't get any further problems with the I2C operation as well.Edited by kiiid 2016-06-30
http://rittle.org
Phil23
Posted: 01:46pm 30 Jun 2016
Just noticed the interpreter didn't return an error on this little mistake.
Dropped me to a prompt & then the watchdog forced a re-start.
Should it have been reported?
As Sub without END SUB? (Typed END IF, in my rush)...
[code]Sub SetFlags
StatFlags=0
If SolarVolts>=SolarMin Then StatFlags=&b000001
If SolarVolts>=SolarThres Then StatFlags=StatFlags+&b000010
If TmpPan-TmpCur>=TmpDifPan Then StatFlags=StatFlags+&b000100
If TmpOut-TmpDif>=TmpDif Then StatFlags=StatFlags+&b001000
If PumpStat="Running" Then StatFlags=StatFlags+&b010000
If PumpRunTime>30 then StatFlags=StatFlags+&b100000
End If
Sub ChkCon
[/code]
Phil.
kiiid
Posted: 01:08am 04 Jul 2016
I think there is definitely a problem with the built-in editor in the 5.2 version. It is very unstable and in Tera Term would exit unexpectedly on its own back to the command line in about 90% of the cases. Then in the command line something like [B[B appears.
I can see the changes in editor.c between 5.1 (which was good) and 5.2, but still can't figure out why is this happening. For now just reporting the problem which I have verified is consistent on a few different boards.
Speaking in more general terms, I think it would be good if the built-in editor is a bit revised and expanded with functionality in the next version. Things like "go to line" or "find and replace", or even a keystroke to remove a line, lot of useful functions are currently missing and can be added. The colourcode option also needs some revised colours because currently they are not looking good on the screen and I always have to disable it.
Edited by kiiid 2016-07-05
http://rittle.org
Posted: 02:12am 04 Jul 2016
Is this the MM+ or the standard MM?
kiiid
Posted: 02:14am 04 Jul 2016
MM+, but it doesn't matter because they both use the same editor
http://rittle.org
