Local Time 22:20 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : B4X Basic
JohnL
Posted: 02:23am 13 Jun 2016
  Quote  B4X programming language is a modern version of Visual Basic.
  Quote  The easy way to develop great, native, Android, iOS, IoT, desktop and server apps.
  Quote  B4R - The simplest way to develop native, powerful Arduino programs!
https://www.b4x.com/index.html
https://www.b4x.com/b4r.html
https://www.b4x.com/b4r/documentation.html
https://www.b4x.com/b4r/help/core.html
Edited by JohnL 2016-06-14
isochronic
Posted: 03:42pm 13 Jun 2016
Looks as though the so-called "double" is only the renamed
single precision, which usual for Arduino.
Info from the the site :
The following data types are available in B4R:
Numeric types:
Byte: 0 - 255
Int (2 bytes): -32768 - 32768. Similar to Short type in other B4X tools.
UInt (2 bytes): 0 - 65535.
Long (4 bytes): -2,147,483,648 - 2,147,483,647. Similar to Int type in other B4X tools.
ULong (4 bytes): 0 - 4,294,967,295
Double (4 bytes): 4 bytes floating point. Similar to Float in other B4X tools.
Float is the same as Double. Short is the same as Int.
The above is true on all boards, including the Arduino Due.
Other types:
Boolean: True or False. Practically it is saved as a byte with the value of 1 or 0.
String: Strings are made from an array of bytes that end with a null byte (byte with the value of 0).
Object: Objects can hold other types of values.
