Local Time 22:19 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Touchscreen to 64 pin Micromite need help
Bermo
Posted: 12:50am 12 Jun 2016
i have a GCM microboard2b 64 pin.
i used the OPTION LCDPANEL ILI9341, Landscape, D/C pin, reset pin [,CS pin] but as i am very new to this i put in the incorrect pin numbers.
what i am asking is does anyone know the correct pin numbers to make the touch screen work. also whilst trying to get it to work i put in incorrect pin numbers for the touch screen. OPTION TOUCH T_CS pin, T_IRQ pin
additionally, when i try to change the pin numbers i can key them in using option etc, and it says restart the micromite, but when i restart the same numbers show up on the option list. i can't change the pin numbers i put in originally.
the pin numbers i think may be correct are for the LCDPANEL 21, 22 and for the
touch 2, 14
when i tried to change the touch numbers it says pin 14 is used on startup.
i have tried to reset using a 10k on 3.3v and the reset pin it resets and the driver loads but i still can't change the pin numbers.
Posted: 01:35am 12 Jun 2016
OPTION RESET will reset all options (ie, remove them). Then you could start again, hopefully with better luck.
Bermo
Posted: 01:40am 12 Jun 2016
Thank you Geoff,
just tried it and it came back with
Error: Unrecognised option
any other ideas
please
mike
Posted: 01:44am 12 Jun 2016
OPTION LCDPANEL DISABLE
OPTION TOUCH DISABLE
should clear things but it sounds like you have an old version of the firmware - what version does it report on boot?
Bermo
Posted: 01:50am 12 Jun 2016
version 4.7
if i disable these how do i enable them?
thank you
Posted: 01:54am 12 Jun 2016
  Quote  if i disable these how do i enable them?
Just execute the normal OPTION commands again.
You are out-of-date with the firmware. Geoff is just about to release V5.2 so If you have access to any sort of programmer you should update. This can also be done with just another Micromite if you have a second one
See this thread for details
Bermo
Posted: 02:03am 12 Jun 2016
ok thank you i only purchased this last week.
and i don't have a programmer
thank you
Posted: 02:28am 12 Jun 2016
you can also use an arduino (any that uses a 328p processor) and a few resistors as a PIC32 programmer if you have one laying around.
rob :-)Edited by robert.rozee 2016-06-13
Bermo
Posted: 02:50am 12 Jun 2016
Thank all i now have the pin numbers changed
disabling was the key
i can now go ahead and calibrate etc
thanks again
bermo
Bermo
Posted: 03:10am 12 Jun 2016
one more problem
i calibrated the touch screen and it said ok
but the touch screen does not work
the LCD test panel works fine with the coloured circles
after calibrating test touch does not work
Posted: 03:24am 12 Jun 2016
Sounds like you still have the wrong pin number for T_CS
panky
Posted: 01:30pm 12 Jun 2016
Bermo,
You should also check the documentation from the supplier on the ILI display - a number available on eBay do not have the touch functionality enabled even though the chip appears to be in place and the jumpers to power it are made.
Panky
