Local Time 22:19 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD Backpack/External Reference.
Phil23
Posted: 03:22pm 11 Jun 2016
So after contemplating & reading about using an external VRef, I notice on the Backpacks I'm using that Pins 2 & 3 are already in use for the LCD touch screen.
Might for now change my thinking on the solar panel output.
Was working towards 1000mV loaded = 1000Watts/m².
Maximum unloaded output from the solar panel is about 2.9V.
Might try & change the loading resistor to try & get around 2.8 volts when the suns at it's brightest or around 1000W/m².
Then just scale it from there for the time being.
Phil.
centrex
Posted: 04:51pm 11 Jun 2016
Hi Phil
I dont know what other pins you are using but pins 4,5,26,24 are all analog and free on the backpac.
Perhaps these could be used for your requirements.
Perhaps not Matherp appears to have pins 2 and 3 locked in to the cfunction.
Edited by centrex 2016-06-13
Cliff
Phil23
Posted: 05:55pm 11 Jun 2016
  centrex said   Hi Phil
Pin 2 is VRef+ & Pin 3 is Vref- on the PIC, I didn't think other normal AIN pins could be used.
Maybe they can, but I don't really know, I just assumed not.
I thought the voltage to be measured could be any AIN, but the reference needed Pin 2 as it's the ACD's VRef+.
Cheers.
Posted: 01:47am 12 Jun 2016
  Quote  Pin 2 is VRef+ & Pin 3 is Vref- on the PIC, I didn't think other normal AIN pins could be used.
Correct I'm afraid - these pins are hardwired in the silicon
Phil23
Posted: 12:59pm 12 Jun 2016
So my alternative could be LM336 connected to say pin 4, Voltage to be measured connected to pin 5.
Assuming Pin 4 returned say 3.5 volts, instead of the 3.25,
And Pin 5 was returning say 2.65,
Corrected voltage would be; 2.46 = 3.25(Ref)/3.5*2.65
Is that going to give me at least better consistency & accuracy?
Thanks.
Posted: 01:33pm 12 Jun 2016
trueRef = 2.5 ' might want to get a precise value.
myRef = pin(4) ' LM336
myCorrection = trueRef/myRef
myreading = pin(5)*myCorrection ' do this for all analog inputs
you can also monitor the 3.3V using a voltage divider.
Eit.
The 3.3 can be determined directly from the reference reading without any other pin getting used. You can monitor other voltages such as the 5V or battery voltage by using voltage dividers.
Edited by TassyJim 2016-06-14
Phil23
Posted: 08:37pm 12 Jun 2016
Voltages I'm reading still seem all over the shop....
Reading pin 4 I think, with a bit of averaging.
Each reading only having a 10% weighting on the previous average....
Volts=volts*100
For n=1 to 10
Volts=Volts+Pin(4)
Next n
Volts=Volts/110
Still looks pretty ordinary...
A few random reading I've observed...
MM Volts Actual Volts
520 800
540 750
1060 1350
1300 1500
Have the panel feeding into the MM, with 27 Ohms Shunt, 0.1µF Ceramic across the shunt; Probably way too low???
3.3V rail on the micro seems rock solid on 3.31V.
Any Suggestions for a better result?
Phil.
