Local Time 22:20 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Default Baud Rate.
Phil23
Posted: 12:11pm 04 Jun 2016
Not suggesting a change, but just curious as to the choice of 38400.
Also is 115200 likely to reduce reliability with ESP8266's?
And for Jim, is MMchat happier with 38 or doesn't really care.
Phil
Posted: 12:55am 05 Jun 2016
  Phil23 said  just curious as to the choice of 38400.
A bit like Goldilock's porridge... not too fast and not too slow but just right.
paceman
Posted: 04:18am 05 Jun 2016
Errr - that'd be 'not too hot and not too cold' Geoff. I know this because I've been recently boning up on Goldilocks with the grandchildren. Still, I'm sure we get your drift
Greg
Posted: 01:25pm 05 Jun 2016
/QUOTE]
MMChat doesn't care much.
If you have a rats-nest of wiring between the USB-TTL converter and the 'mite, you might have big problems with the faster rates.
If you go with the high rates, you might need to have bigger delays between lines so no real gain.
Posted: 03:11am 06 Jun 2016
You've been boning up on Goldilocks paceman?
Posted: 03:45am 06 Jun 2016
  paceman said   Errr - that'd be 'not too hot and not too cold' Geoff.
Yes, but I was trying for a humorous analogy.
paceman
Posted: 04:30am 06 Jun 2016
  Grogster said   You've been boning up on Goldilocks paceman?
Ummm, yes and no Grogs. Thought I might edit that word but that would have called attention to it.
