Local Time 21:20 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Simple Comms between MM’s
Phil23
Posted: 12:36pm 02 Jun 2016
Been reading the examples in the Serial Comms Appendix, and get a general idea on what I need to do for MM1 to ask MM2 for a variable.
Very basically,
MM1 says "Send me EvaporatorTemp",
Interupt Sub on MM2 is triggered,
MM2 Says "This is EvaporatorTemp"
Which triggers a sub on MM1.
Is it possible to do something similar with the console ports?
The two MM's have their consoles sitting on 192.168.55.181 & 182.
That would mean each ESP8266 would need to know to connect to each other and I don't know if that is doable.
Alternatively I have some HC-12's that could do the task once the communications are established with wires.
Phil
Posted: 02:33pm 02 Jun 2016
Rather then the console, you would normally do this kind of thing via I2C, SPI or in the case of the HC-12 or ESP8266, the serial ports.
Taking your RF module concept, this is best done via serial ports and NOT the console, as the program can they implement controls on the data(such as checking for a qualifier), which the console can't do.
Why do you want or need it to be via the console?
(not being critical, i'm just curious)
Phil23
Posted: 09:30pm 02 Jun 2016
Reason I wondered about the console port is that it already has an ESP8266 on it for VT100 output to a phone terminal and for programming etc.
Don't think I'd like 2 Wi-Fi per MM module.
Already have quite good data displayed in VT100 format that is port forwarded thru the router to the Internet, an can monitor that on my phone.
Plan to also add some control back in as well.
Phil.
