Local Time 20:22 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Thoughts on Double Tap etc
Phil23
Posted: 11:26am 20 May 2016
Thinking that having the ability to Tap, Double Tap or Long Press the touch screen for different actions would be useful.
Any thoughts on implementing this?
Here's what I've tried.
Single & Long Press seem to work, Double maybe occasionally.
[Code]
Dim TouchType as String
Dim TouchTime as Integer
If Touch(x)<>-1 then
TouchType="Single Touch"
Pause 200
Timer=0
Do While Touch(x)<>-1
TouchTime=Timer
If TouchTime < 500 Then
TouchType="Double Touch"
Elseif TouchTime > 500 Then
TouchType="Long Press"
Endif
ScreenTouched
Endif
loop
Sub ScreenTouched
Print CHR$(27)+"[f"; : Print CHR$(27)+"[2J";
Print TouchType
Pause 1000
Print "Not Touched"
[/code]
Phil
Phil23
Posted: 11:40am 20 May 2016
I know simple timing probably won't work reliably; Maybe need to use interrupts, which I haven't gone into yet.
Basic Logic sounds simple:=
Touch <> -1
Then Touch = -1
Then Touch <> -1
Inside a time of say 300ms
Otherwise if your finger is held down & touch < say 500ms a long press is recorded.
Could be used for things like Tap to view or Long Press to Edit.
Phil.
Posted: 11:43am 20 May 2016
Don't forget that you can set an interrupt on the IRQ signal (ie, touch down) from the touch controller (page 19 of the 5.2B1 manual). That would make it easier as the timing could be wrapped up in the interrupt subroutine and independent of the main program.
Phil23
Posted: 11:27am 21 May 2016
  Geoffg said   Don't forget that you can set an interrupt on the IRQ signal (ie, touch down) from the touch controller (page 19 of the 5.2B1 manual). That would make it easier as the timing could be wrapped up in the interrupt subroutine and independent of the main program.
Thanks Geoff,
I'm not sure exactly how the interrupt behaves.
What happens if you are already in the Sub it calls when a 2nd interrupt is generated?
Does it behave like an EXIT SUB situation & return to the beginning again?
Phil.
Phil23
Posted: 11:44am 21 May 2016
Think I'm missing something in my basic logic here.
Any thoughts?
Seems to relatively reliably return Single Touch & Long Press.
I do occasionally see it output "Double Touch", but it's a bit random.
Wasn't sure how the interrupt behaved once inside the sub it calls so tried disabling it & re-enabling it on END SUB.
Don't know if that improved it or made matters worse.
Any feedback on the actual sensitivity & responsiveness of the actual panels? I do think mine is way less responsive than say my phone, but then I do expect that given the different technologies.
Anyone with a Touch handy like to give it a test on theirs for feedback?
Phil.
[Code]
SetPin 15, intl, LCDTouch
'Empty ATM
loop
Sub LCDTouch
SetPin 15, Off
Timer=0
Pause 200 'Pause after initial touch
Do While Touch(x)<>-1 'Look for 2nd touch or holding belong 200ms & measure time
TouchTime=Timer
If TouchTime < 350 Then
Endif
''''''''''''''''''Endif
Print TouchType
Pause 1000
Print "Not Touched"
[/code]
Edit:- Extra non matched End If in above when I posted.
Edited by Phil23 2016-05-22
Phil23
Posted: 12:19pm 21 May 2016
Tried adding some timing measurements to the output to assist with debugging.
[Code]
'Empty ATM
loop
Sub LCDTouch
SetPin 15, Off
Timer=0
Do While Touch(x)<>-1 'Measure 1st touch time
TouchTime=Timer
Pause 100 'Pause after initial touch to wait for 2nd touch, Don't know what's a good value.
Do While Touch(x)<>-1 'Look for 2nd touch or holding belong XXXms (set above) & measure time
TouchTime=Timer
If TouchTime < 400 Then
Endif
Print TouchType, "Touch Time =", TouchTime
Pause 1000
Print "Not Touched"
[/code]
Posted: 11:20pm 21 May 2016
  Phil23 said  What happens if you are already in the Sub it calls when a 2nd interrupt is generated?
Assuming that you are in the sub because of an interrupt the second interrupt will be ignored until you return from the sub. This is why your time in an interrupt sub must be as short as possible.
You might be meaning that you called the sub from somewhere in your program and while you were still in that sub an interrupt occurred to send you recursively into the sub. This will turn your hair grey and cause nightmares. To avoid this never call an interrupt sub from within your program when an interrupt might occur.
Phil23
Posted: 03:19am 23 May 2016
Assuming that you are in the sub because of an interrupt the second interrupt will be ignored until you return from the sub. [/quote]
Yes that was what I was referring to; the initial touch sends me into the LCDTouch Sub. So you are saying the Second touch would again generate an interrupt, but it would be ignored.
Is it just the subsequent Touch interrupt or all interrupts?
[Quote] To avoid this never call an interrupt sub from within your program when an interrupt might occur.
Not quite sure what you are meaning in this statement.
Phil
Posted: 03:47am 23 May 2016
Think of it like this:
Never call an interrupt sub from your main program - ever.
Interrupt subs should be specifically dedicated to the interrupts that call them.
So if you had an interrupt called SUB MYINT, then NEVER call MYINT as part of your normal code. You COULD call it, but just DON'T!
Otherwise you could end up with the hair-pulling example Geoff was talking about, where you have recursion - "If we had an index file, we could look it up in the index file under index file!" - Can anyone name where that quote comes from?
Phil23
Posted: 04:07am 23 May 2016
  Grogster said   Think of it like this:
Got it now!
What if a 2nd Different interrupt is triggered while in an interrupt sub?
Is it ignored? As in all interrupts ignored?
OR does it jump out of the first sub.
Unlike my first example of the same interrupt while already in the sub that the same interrupt called.
CircuitGizmos
Posted: 04:28am 23 May 2016
  Grogster said   "If we had an index file, we could look it up in the index file under index file!" - Can anyone name where that quote comes from?
That quote comes from two posts above mine. Which I just quoted in my post by clicking quote.
Talk about useless recursion!
Posted: 04:47am 23 May 2016
@ Phil - As Geoff said, if you are in an interrupt, and another interrupt is tripped, all other interrupts will be ignored until the first one is returned.
So, in other words, if you have a 2nd interrupt instance while still in the first interrupt, that 2nd one will be ignored. This is the primary reason for not hanging around inside an interrupt. Don't even process any code(bar very simple stuff like a few IF/THEN/ELSE type commands) in an interrupt. My preferred method is to simply set a flag, and exit immediately. Then have your main code analyse the flags and take the appropriate action.
It IS confusing, until you get your head around how they work, but interrupts are a wonderful thing, and a fantastic feature to have on the MM.
@ CG - Clever! Edited by Grogster 2016-05-24
Posted: 02:33pm 23 May 2016
The way the interrupt system works is that MMBasic does not check for interrupts while it is processing an interrupt. This is to prevent uncontrolled recursion which could be a problem due to the way the interpreter and BASIC works. When the program returns from the interrupt sub it will recommence checking for interrupts.
For this reason you should make sure that you spend as little time as possible in the interrupt sub. For example, if you are detecting touch down interrupts and only spent 10mS in the interrupt sub you are guaranteed to catch a second touch down interrupt because it would be impossible for someone to tap faster than this.
