Forum Index : Microcontroller and PC projects : Converting other basic to Micromite Basic
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
I'm "TRYING" to learn/work out the differences between the types of basic compared to Micromite Basic so I can convert Bascom and Picaxe programs if and when needed. If anyone is able to help me, could you tell me what each of the lines below would be in Micromite Basic please? [code] 'Data array for i2c communication Dim Value_array (24) As Byte Dim Ut As Long Declare Sub I2c_write (byval Device_adres As Byte, byval Reg_adres As Byte, byval value As Byte) Declare Function test1() As Long Declare Function test2_64 () As Dword Txt = Str (t) Txt = format (txt, "00.00") Sub I2c_read (device_adres As Byte, Reg_adres As Byte, Value_count As Byte)*** Local X As Byte (dim X As Byte????? can I miss out the Local bit???) Local Y As Byte Y = Value_count - 1 Shift Up, Left, 8 Up = Up + Value_array (2) Local Var1 As Long Local Var2 As Long Local X As Long Local Var1 As Double Shift X, Right, 2, Signed *************************** I2cstart I2cwbyte Device_adres I2cwbyte Reg_adres I2cwbyte value I2cstop *************************** I THINK the last bit should be (not sure what cwbyte means though) i2c open 400,1000 '400KHz bus speed ? ? ? i2c close [/code] I can work out most of it myself, but the bits above I'm totally stuck on what they mean or would be in Micromite Basic |
Bascom looks like it has 8 types of variables instead of the 3 in MMbasic. So for BYTE, WORD, DWORD & LONG use INTEGER. For SINGLE & DOUBLE use FLOAT. Found some good stuff here. Cheers Phil |
Anyone else able to help? |
I don't know Bascom and don't know what device you are trying to talk to so I can only guess. I2cwbyte is probably short for I2C WRITE BYTE In MMBasic, I would try I2C WRITE Device_adres, 1, 2, Reg_adres, value Jim VK7JH MMedit |
