Forum Index : Microcontroller and PC projects : MM+ Counter frequency
| Tinine Guru Joined: 30/03/2016 Location: United KingdomPosts: 1646 |
I need to reliably and constantly keep a pulse count of approximately 100KHz. Missing a beat due to other chip activity is not an option. Is this possible? Cheers! Tinine |
Yep, configuring a pin as a counting input will count at up to 300KHz. This is done in the background and it will not miss a count. Look for the command: SETPIN nn, CIN You have four I/O pins that can be used for this function. Geoff Geoff Graham - http://geoffg.net |
Cool! So no difference between MM and MM+ then? Cheers! Tinine |
