Local Time 19:30 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMedit Variable Usage Report.
Phil23
Posted: 02:43am 09 May 2016
Hi Jim,
FYI I Just noticed this:-
Variables which are only refered to in one line:
None 3
White 78
Reset 113
Lines of code referenced:-
[Code]
3. Option Default None
78. Text MM.HRes/40, MM.VRes*5/8, "Therm Ohms", LM, 2, 1, RGB(White)
113. OneWire Reset PinTmp
[/code]
Also notice that the colours in the other TEXT ..... RGB(Colour) lines are listed as variables.
Phil.
Edited by Phil23 2016-05-10
Posted: 01:41pm 09 May 2016
What that indicates is the KEYWORDS are missing from the syntax file.
I had already fixed the colours and RESET.
NONE has now been fixed as well.
The fixes will be in the next full update along with any more that are found.
Justplayin
Posted: 02:03pm 09 May 2016
Here is a couple more for you Jim.
Restart 695
PU 846
695 CPU Restart
846 I2C Open 100, 200, PU
Also, referred is misspelled in your Variable Report.
--Curtis
Posted: 02:08pm 09 May 2016
RESTART I had, PU now added
Spelling will be fixed.
