Local Time 09:17 31 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMedit caps etc.
Herry
Posted: 10:34am 23 Apr 2016
Using MMEdit. Great program. Have a couple of small probs. I wish to disable the automatic caps for keyword feature as I find it makes me sloppy about using the caps key. I go: Files > Preferences, uncheck the Caps for keywords box and then save preferences. However, that box automatically gets checked the next time, ie the preference is apparently not saved.
Also, how do I make the printouts larger? The font size setting only affects the screen.
I tried emailing the developer via the address given in the help menu, but this has just bounced.
Senior?!  Whatever it says, I'm a complete and utter beginner...
palcal
Posted: 11:36am 23 Apr 2016
Send a PM to TassyJim or wait until he reads your post.
Paul
Posted: 12:33pm 23 Apr 2016
In preferences, if you have "always start with these settings" set,
the settings in preferences are used every time you start MMEdit.
If not, MMEdit remembers the last used settings.
You can change the current settings from the "view' menu.
There are no options to change the font size for printing. YOu could copy the program into another text editor and change it there.
I am not sure why the email to me bounced, it hasn't changed at this end. It might have been a temporary problem with my hosting service or your ISP.
Herry
Posted: 02:51pm 23 Apr 2016
Thank you, and 73 de G3UIV/VK2DRR. And for me, it all started with the Z80, even earlier with the HL2!
