Local Time 20:22 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Thanks Jman
Phil23
Posted: 01:09am 06 Apr 2016
Just a quick note to acknowledge you help with getting multiple DS18B20 temp sensor read off a single IO pin with reduced cabling.
It's all working now. Currently reading 3 sensors off a single pin.
Most of the final issues I encountered were simply due to inexperience.
It's great to have help on hand in tackling these projects an a beginner.
The Search for multiple 1-Wire devices code you posted, along with the code for reading multiple temp sensors are really useful & should be beneficial to other.
If I'm feeling really brave, I might even try & get the search routine to try & return it's data to an array.
Thanks & Cheers
Phil.
jman
Posted: 05:58pm 20 May 2016
Hi Phil
Sorry i missed this one
You are more than welcome
Jman
Posted: 07:35pm 20 May 2016
This is nothing to do with Phil23's project, but jman has done stellar work helping with the code for my Amp-A-Mite stereo project. He basically did a complete re-write! I didn't ask him to, he was just tinkering with things, and before you know what had happened........
So he has my thanks too.
Did you ever work out what was stopping the spectrum analyser in the new code?
