Local Time 16:42 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite LCD backpack PCB
Greg Fordyce
Posted: 09:39am 28 Mar 2016
Does anybody have pcbs for the LCD backpack? I am looking for a bare pcb in either size. If no one has any I'll order some 2.4 inch from China.
Greg
DaveC166
Posted: 10:02am 28 Mar 2016
Hi Greg, Silicon Chip magazine sells backpack PCB's for both the 2.8" and 2.4" LCD's
Justplayin
Posted: 10:30am 28 Mar 2016
BigMik sells his own version. See BackPack-170 for a description of his offering and PM him if you are interested.
--Curtis
Greg Fordyce
Posted: 10:42am 28 Mar 2016
Thanks Dave,
The postage to Scotland is more than the board so I am hoping to find some in the EU.
Greg
paceman
Posted: 04:05pm 28 Mar 2016
  Justplayin said   BigMik sells his own version. See BackPack-170 for a description of his offering and PM him if you are interested.
Mik's boards are great - I've got quite a few. They're also very low priced and his posting is much cheaper than Silicon Chip's. Be careful with the connections though, there are some important differences on his original through-hole backpack and the later SMD backpack to Geoff's "LCD Backpack" described in the Silicon Chip article. Mik might have a new one coming though - see his "photo" link latest board on his 11:35 post yesterday.
Any more info Mik?
GregEdited by paceman 2016-03-30
Greg Fordyce
Posted: 11:11pm 28 Mar 2016
Cheers all, I've ordered from BigMik. Got 3 boards for less than £2 each including postage.
Greg
Posted: 12:27am 29 Mar 2016
Thank you Curtis, Greg and Greg,
I don't have a schematic to compare my board to Geoff's backpack as I no longer subscribe to silicon chip. But the good thing is mm basic can be configured for almost any pin configuration..
Greg, I expect you should have your boards early next week.
Lightrock
Posted: 01:27am 29 Mar 2016
Geoff's Backpack in Silicon Chip can be found on his web site http://www.geoffg.net/MicromiteBackpack.html with the full construction pack at the bottom of the page.
Roy
Greg Fordyce
Posted: 04:33am 29 Mar 2016
One of the differences between Geoff's and bigmik's is the backlight control. Mick's looks interesting as it can be controlled from the maximite. Geoff's is a simple potentiometer.
Posted: 06:12pm 29 Mar 2016
@Roy,
Thanks for that, I didn't even stop to think it might be published on Geoff's pages.
@Greg,
Yes you can control the brightness from 0 (off) to 100% (on) via pin 26 PWM output.
If you wish to use pin 26 for something else you can omit D1, R6, R7, R8 and Q1 and solder a shorting link from the pad for the Emitter of Q1 to 3v3. That will permanently keep the back light on 100% and allow pin 26 to be used for other purposes.
Bill.b
Posted: 06:28pm 29 Mar 2016
Hi all
I have used mick's backpack board for the garage distance project
as described in SC, It works great. The only thing is do the LCD
configuration as described in mick,s manual before downloading the
.BAS file.
