Local Time 15:15 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pin 7 Com1 enable
Herry
Posted: 03:40pm 26 Mar 2016
I'm puzzled about the purpose of this pin. I am reading from a GPS module into the MM using pin 22 (Com1 RX). I have the program line set as OPEN COM1:9600 AS #1 and I am reading from GPRMC, parsing the stream. This all works so what is the purpose of Com1 enable?
Edited by Herry 2016-03-28
Senior?!  Whatever it says, I'm a complete and utter beginner...
Zonker
Posted: 05:57pm 26 Mar 2016
Hey Herry...
The Com 1 EN pin is used to control an Rs-485 Transceiver IC... This IC allows for serial com using 3 (or 2 and GND) wires, but is different the Rs-232 in that the two wires form a half duplex type for data transfer between 2 or up to 256 "nodes"...
The wires use a differential type transmit/receive system inside, and as such, can carry the serial data stream a very long distance between each "node" if needed.
Since the same set of wires is used to transmit AND receive data, a pin from the Micromite is needed to control the IC's Tx-Rx functions. Then, whan you want to send a massage, or "packet" of data to the other nodes, the Micromite automatically controls the IC's control pins for you...
Look in the Micromite manual on page 82 "IEEE-485" to read about it. I helped Geoff test this subsystem, as I needed it for a project, and I am glad he included it into the MM firmware.. I have used it several times and it works like a champ..!
Hope this helps..! Edited by Zonker 2016-03-28
Herry
Posted: 06:02pm 26 Mar 2016
Thanks. So not applicable to my program, I suppose.
