Local Time 14:18 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : question about terminal and micromite
f1fco
Posted: 09:00am 23 Mar 2016
hello to all,
when I connect a terminal (of Geoff of course) to a micromite via serial link at 38400 bauds, what "code" is sent from teminal to micromite ?
when I type "A", ok the code is "A",in serial mode
but when I type F1, or F2... what code is sent ?
and in EDIT mode, what code for cursor up, down, left, right...
is it a table available of all the codes ?
thank you for help
Pierre, from Nimes, south of France
73s de F1FCO
Posted: 11:10am 23 Mar 2016
The manual for the VTterminal may have more details but this is what I send from MMEdit for keys with multiple bytes:
VTk$=key$
'print len(VTk$),asc(VTk$), asc(right$(VTk$,1))
if len(VTk$)>1 then
VTcmd=asc(right$(VTk$,1))
select case VTcmd
case 13
VTk$=""
case 27
VTk$="" 'chr$(27)
'print "<ESC>"
case 37 'left arrow
VTk$=chr$(130)
case 38 'up
VTk$=chr$(128)
case 39 ' right
VTk$=chr$(131)
case 40 ' down
VTk$=chr$(129)
case 45 ' insert
VTk$=chr$(132)
VTins=1
case 46 ' delete
VTk$=chr$(127)
case 36 ' home
VTk$=chr$(134)
case 35 ' end
VTk$=chr$(135)
case 33 ' page up
VTk$=chr$(136)
case 34 ' page down
VTk$=chr$(137)
case 18 ' alt
VTk$=chr$(139)
case 112 'F1
VTk$=chr$(145)
case 113 'F2
VTk$=chr$(146)
case 114 'F3
VTk$=chr$(147)
case 115 'F4
VTk$=chr$(148)
case 116 'F5
VTk$=chr$(149)
case 117 'F6
VTk$=chr$(150)
case 118 'F7
VTk$=chr$(151)
case 119 'F8
VTk$=chr$(152)
case 120 'F9
VTk$=chr$(153)
case 121 'F10
VTk$=chr$(154)
case 122 'F11
VTk$=chr$(155)
case 123 'F12
VTk$=chr$(156)
case else
'print len(VTk$),asc(VTk$), VTcmd
VTk$=""
end select
end if
if len(VTk$)> 0 then re=MMsend(VTk$)
You could easily write a small program in MMBasic to print the HEX value of any keypress. That way you will be sure.
f1fco
Posted: 12:04pm 23 Mar 2016
thank you Jim,
I will try it
Pierre.
73s de F1FCO
